Good Day mga sir/maam just got our 2nd hand optra wagon 07 model. i have a question i want to replace the headunit bat nung nag ikot ikot ako sa marikina hindi nila 100% sure kung kaya nila i tap dun sa steering wheel yung controls. kasi po diba sa stock na head unit natin pwede ma control via steering wheel. so ask ko lang po sa mga may optra na nakapag change na ng headunit and speakers kung saang shop nyo ko ma recommend.
if it is an aftermarket HU, it cannot be tapped dun sa controls sa steering wheel.
best thing you can do is to have your current HU repaired, or get something which is the same na compatible dun sa SW controls mo.
medyo mahirap cya i tap, i still trying to figure it out pa... since kasii na yung HU nya eh walang accessories na wire negative and constant pasitive lang ang meron ... kaya TRY MO NA I ON ANG STOCK HU NYA WITHOUT THE KEY GAGANA YUNG RADIO NYA...
pero pag papalitan pwede cya langyan nalang ng accessories wire tap.
yes tangal talaga yung buong panel bago ma access ang HU .
tangal muna ang negative ng battery then tangal glove box,then frame ng glove box, bago ma access ang selector ng heater core,
then kabila naman sa driver side same thing para ma access yung selector ng aircon, bago matangal yung pinaka panel nya using spatula or anything na manipis pero matigas,
warning; pag tinangal ang center panel without removing the two selector cables... sira ng guide ng selector...
