Results 1 to 9 of 9
- Jun 2016
- 23
June 22nd, 2016 12:35 AM #1Hi,
Sino po sino may idea sa Normal Oil Pressure range? Kasi I observed last April nasa 60% then last Month I observed na bumaba sya sa 38%, then last week first PMS ni Trax, then kanina when I checked sa Menu icon indicator nasa 29% sya... Normal po ba sya? Thanks.
June 22nd, 2016 05:04 AM #2
Konti lng owners ng trax. Anyways is this on the instrument gauge cluster? Normally oil pressures arent that important. Fuel pressure is important. Maybe you're seeing boost pressure from the turbo?
Have a look at the owners manual. It details everything you see on the instrument cluster.
- Jun 2016
- 23
June 23rd, 2016 05:59 AM #3
Yah! on the instrument gauge cluster. It is the pitcher like icon.. Attachment 32931
June 23rd, 2016 08:06 AM #4
Ah pitcher. Yeah its oil pressure. It shouldnt light up. It means you are probably low in oil. Or you need an oil change.
Then percentage means oil life. 0% means time to get an oil change.
Chevrolet has an oil life calculator. Depends on how you drive and how long the oil has been inside.
- Jun 2016
- 23
June 26th, 2016 03:54 AM #5
- Jun 2016
- 23
June 26th, 2016 04:43 AM #6
June 26th, 2016 08:44 AM #7
Chevrolet oil life monitor pala aka OLM
Na brain fart ako when i said oil life calcu... toinks.
Similar meaning but chevy uses "olm"
- Jun 2008
- 1,741
June 26th, 2016 09:29 AM #8Monitor lang yan ng svc hrs next oil change. Dapat I reset every oil change.
Sent from my Lenovo A7000-a using Tsikot Forums mobile app
- Jun 2016
- 23
June 27th, 2016 02:42 AM #9
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
