I got this big problem with my car for about 2 months na.
Chevrolet Captiva 2.0 diesel AT 2009
Before, engine stops during high speed running from 70-80kph up..
I brought the car to chevrolet for them to solve it, they just clean something without replacing any spare parts then after 5 days bumalik yong problem tapos na addan pa, engine shuts off when shifting to reverse. Chevrolet told us that the ECM is bad and quoted me with 90k... wtf.. I think this is too overpriced.
I decided to let other shop check the car (previous chevrolet company here in cebu), same thing they just clean it then bumalik nanaman ang problema. They told us that the fuel pump should be replaced... not just the pump but the assembly thing with a price of 21k and not properly explaining why assembly talaga. I doubted their findings kasi parang ang layo naman ata sa fuel pump so dinala ko ulit sa ibang shop tapos same findings, the pump.
I decided to purchase the assembly from manila, I got it 10,500 and saved 10k compared sa casa.. and it's oem pa. Sorry mataas na explanation ko, my point in this line is mahal talaga ang casa. So back to the problem, new fuel pump assembly was installed but the problem wasn't fixed.
One more thing, Car wont start again if the key's not reinserted in the ignition.
I hope someone can enlighten me and help me fix this problem.
But it's not sure yet if sira ba talaga yong ecm, pa check ko na lng, buti sana if my shop na my spare ecm tapos i try palitan if ma solve ba yong problem.
so hanap ka ng may captiva and ask him to swap ecm with you.
or, last resort, tell the casa if they are sure of their diagnosis, that they install a new ecm in your captiva and if the problem remains then you don't pay. they of course will remove the new replacement ecm. you will only pay for the new ecm if the problem gets solved.
Regarding that matter na i balik nila yong item if hindi ma solve yong problem, ayaw nila.. yong casa na pervious chevrolet. ewan ko lng sa bago. We already have a conflict sa bagong chev due to their crappy services, ayaw ko ng bumalik don.
buti sana if merong mabait na magpapa hiram ng ecm nya.
Try to reset ECU or ECM. Usually when changing the fuel pump, battery has to be removed or disconnected. Once a battery is disconnected or fuel pump is replaced, the ECU has to be primed or reset. Minsan ito hindi ginagawa ng casa boys na di marunong. Try disconnecting the negative terminal of your battery for at least a minute then reconnect. Insert key then turn to on position (don't start car) for 15 seconds then turn to off position for at least 5 to 10 seconds then turn on again for 15 seconds. Do this 3 times or repititions then remove key. Reinsert key and start car. Thios is how ECM's are usually reset by owners. Try this it might help. Some say na when doing this turn off everything like radios and close the doors. Once tinanggal mo na key open and shut door as if you are entering and close mit before restarting.
ECU has been reset after installing the pump pero sira parin. Now the mechanic is saying na fuel rail pressure regulator daw but not that sure. Another gamble to take.
Is the captiva covered under the 5 year powertrain warranty? I read somewhere that chevy offers 5 year powertrain warranty. Not sure though if it applies to 2009 model of the captiva. Try to look at your warranty booklet if it is indeed. If it is, maybe you can claim under it since the your powertrain and/or its components might be the one that is defective.
I suggest you go to thread of maintenance by MARIO on the next page. He do maintenance and repair and i think his number is posted there. Try to call him to give you some ideas on what to do next.
