Results 3,011 to 3,020 of 4415
- Dec 2012
- 293
March 10th, 2013 07:17 PM #3011I'm not comparing the vehicle's price tag, what I'm comparing are their capabilities on and off road and it's this statement "Also, TBZ was built as an off-roader and I think, for countryside leisure driving pleasure, not a speed demon.If you want an SUV to drive that fast, better get the new Forester, since it's turbo-charged." for me the TrailB is not singularly built for off roading but is built for both terrains with maintaining as much comfort and capabilities of an on road vehicle this is why We are surprised on the top speed this vehicle can achieve. Also the TrailB is turbocharged as well and the forester is gas only.
- Jan 2013
- 31
March 11th, 2013 05:27 AM #3012
March 11th, 2013 10:51 AM #3013
I had my 1st PMS ( Chevy North) last saturday milage registered KM 3,800 almost 5 months in use, here my expenses :
Fuel System Flushing additives P 803.40
Engine Flush 504.00
Brake Paste ???? 160.00
7 ltrs ACDelco Dexos2 *780/ltr 5460.00
Brake Cleaner 235.00
Oil Filter 755.00
Wind Screen Cleaner 160.00
Sundries 500.00
LABOR 1314.00
TOTAL ++++++++ 9891.00
The TrailB was cleaned & shining again, by the way I learned from the Technical Supervisor that we can't use the EXCEL Motolite Battery due to difference sa terminal, sa trailB has two terminal for positive & negative plus extra for reverse( I don't know what is this). Life span of our EOM battery about 1 1/2 years daw ?????
- Jul 2006
- 3,376
March 11th, 2013 11:04 AM #3014
March 11th, 2013 11:41 AM #3015
March 11th, 2013 12:01 PM #3016
Naku tama nga sabi nila, mausok si Trailblazer (hehehe)
*Photo courtesy of Chevy Phil FB
March 11th, 2013 12:18 PM #3017
Im still figuring out the difference of Delco batteries compare sa other batteries available sa local outlets like EXCEL MOTOLITE, I tried to check the different model of Delco batteries sa internet but wala akong makitang other terminal besides the negative & positive, what is this revesrse connection the chevy people are saying???, around P 7K plus daw ang battery nila, sabagay if it is true na around 1 1/2 years daw ang life ng delco batteries, I still have a long way to worry about it, I will cross the bridge when Im there he he he
March 11th, 2013 12:21 PM #3018
- Mar 2010
- 95
March 11th, 2013 12:56 PM #3019
March 11th, 2013 03:19 PM #3020
Delco Batteries
As per my scanty search the Delco Batteries actually are the same as the batteries locally available, except the terminal are reversely designed, this contradict the explanation of the Chevy Technical dept. that another terminal besides the 2 standard pole can be found in Delco Batteries tsk tsk tsk..
* jojo728, thanks for the input about Delco Batteries.
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
