Results 2,951 to 2,960 of 4415
- Jul 2006
- 3,376
March 5th, 2013 08:17 PM #2951Di pa rin pwede. Di kasi yan dexos2 compliant. I'm currently negotiating with Autoplus for them to bring the Motul Specific dexos2 5W30 oil here. Saw its bottle sa website nila, nakalagay 100% synthetic oil, meaning fully synthetic siya unlike yung AC Delco dexos2 5W30 na inimport ng TCCCI which is synthetic blend, which I think is semi synthetic.
Spoke with *delta00 a while ago regarding his 1st PMS. He said he was asking for the dexos2 compliant oil back then, but Chevy Alabang claimed there's none back then kaya mineral oil nilagay. He told me mas gusto niya yung dexos2 in order to have a longer Oil Change Interval and straightforwardly said to me na hindi na siya magpapaPMS sa Chevy Alabang. Sa Greenhills-EDSA or sa Pampanga na ang next PMS niya.
- Mar 2010
- 95
March 5th, 2013 08:49 PM #2952Motul H-Tech 100 Plus is 100% fully synthetic. But recommended for gas engine. There are Motul Specifics, like dexos 2 for GM-Opel and 913C for Ford.
Before going to a car care shop for your next oil change.. Read this first.
FACT: Not all OILS are EQUAL and not all SYNTHETIC Oils are 100% SYNTHETIC.
Engine Oil Products Available in the Philippines.
Auto-Rx (Philippines) | About Oil
So which is better the Synthetic Oil? Group IV or Group V?
Welcome to Motul
- Dec 2012
- 185
March 5th, 2013 08:59 PM #2953
- Jul 2006
- 3,376
March 5th, 2013 09:25 PM #2954Even though Motul H-Tech 100 is fully synthetic, it doesn't satisfy the dexos2 specification that's why hindi siya pwede for our Duramax Diesel engine.
Up to you if you want to use Mineral oil. Basta ito isipin niyo, if you opt for dexos2 certified oil on the 1st PMS, babalik ka pa rin for the next 5k km PMS, pero walang papalitang filter and other parts since every oil change lang palit ng oil filter. Ichecheck lang ng casa mga bolts and other components that need to be tightened, labor lang babayaran. Whilst if you opt for mineral oil 15W40 API CI-4 or CJ-4, every 5k kms ang Oil Change Interval, kada balik mo sa casa oil change at palit ng oil filter ang gagawin aside from the checking ng bolts and other components, parts and labor ang gagastusin.Last edited by numbah5; March 5th, 2013 at 09:43 PM.
March 5th, 2013 10:28 PM #2955
Actually this statement by numbah5 is the same advise that chevy EDSA-GH has given to me i.e. after the 1st PMS at 5k kms, the next scheduled PMS would be on the 10k kms and the next oil change and filter change is on 15k kms which is after 10,000kms from the 1st oil change.
- Dec 2012
- 185
March 6th, 2013 08:08 AM #2956Thanks a lot Sirs for the great discussion on motor oil. I now know what to do in my first PMS.
March 6th, 2013 10:33 AM #2957
This is what & plan Im going to adopt on my initial PMS, if the casa can't supply full synthetic, then I will accept the AC Delco Dexos 5W30( Semi -synthetic) by the time I will have my next PMS, then Im pretty sure that remnants of mineral oil are already absorbed by semi-synthetic motor oil, safe to say that the next change oil to full synthetic will be almost 100% pure & siguro by that time full synthetic motor oil will be readily available sa casa or sa third parties sources.
March 6th, 2013 10:37 AM #2958
- Jul 2006
- 3,376
March 6th, 2013 10:47 AM #2959Sana magkaroon ng magandang result ang pakikipagusap ko sa Autoplus. Para magkaroon na ng other dexos2 certified oil na pwedeng gamitin sa trailblazers natin at fully synthetic din. Kasi yun nga, mapa semi synthetic or fully synthetic dapat dexos2 certified oil pa rin ang gagamitin natin.
March 6th, 2013 12:42 PM #2960
Mga sirs! FYI: I confirmed with Chevy-GH na yung AcDelco dexos2 nila na synthetic blend is a fully synthetic oil kaya they recommend the next oil change after 10k kms.
high idle RPM at engine start
