Results 2,431 to 2,440 of 4415
January 29th, 2013 11:50 AM #2431
- Jul 2006
- 3,376
January 29th, 2013 12:23 PM #2432Don't use the regular diesel fuel of the Big 3 oil companies. Masisira in the long run ang common rail system ng TrailB mo. Pag jeepney and old school diesels ang regular diesel fuel ng Big 3. If you want a cheaper diesel fuel that won't damage the engine in the long run, use Unioil's EuroDieselIV. The premium diesel fuels of Petron and Shell and the regular diesel fuel of Unioil are the suitable diesel fuels for any modern diesel engines (common rail direct injection system)
January 29th, 2013 12:51 PM #2433
sige sir salamat sa advice. problema lang dito sa probinsya kasi walang gaanong premium na diesel.
- Jul 2006
- 3,376
Tsikot Member Rank 3
- Aug 2004
- 2,452
January 29th, 2013 01:06 PM #2435Originally Posted by jonzjitsu
haha gawain ko rin yan. Be careful though mahigpit skyway ngayon sa over speeding may mga ninja sila dami na din nahuhuli.
ok umabot 185kph, malamang aangat pa 'yan pag mas may buwelo.....
January 29th, 2013 01:46 PM #2437
- Dec 2012
- 293
January 29th, 2013 01:59 PM #2438I remember nung ondoy nilusong ko yung strada ko abot hood yung water(walang snorkel)... wala naman any problems i did this 5-8 times... tapos 3 months after nagpakarga ako in a nearby petron station full tank after 3 days umilaw check engine ko. Dinala ko sa casa they said may tubig yung tank ko... so they drained the tank all in all it cost me 25k along with the maintenance narin hay.
January 30th, 2013 10:36 AM #2440
Im not quite sure about the premium diesel, kasi the mitsubishi tech. dept they don't recommend premium diesel for Strada, also para akong may nadinig or nabasa na chevy would prefer regular than premium diesel oil. Im using regular (petron or shell) diesel & if matagal tagal na ang TrailB ko will introduce the same medicine Im doing to my strada , once in a while for every full tank of DO I will mix half liter kerosine.
high idle RPM at engine start
