Results 221 to 230 of 4415
September 19th, 2012 11:08 AM #221
2012 Chevy Trailblazer demo unit is making rounds at different Chevy dealers.
was invited to view it at Chevy Otis yesterday but I was unfortunately unavailable.
call up nearest chevy dealer and ask when you can view it.
September 19th, 2012 11:50 AM #222
Chevy Alabang texted me the prices and available colors:
Trailblazer 4x2 M/T - P1,368,888
Trailblazer 4x4 A/T - P1,718,888
Black, Silver, Gray, Blue, White
- Jul 2008
- 485
September 19th, 2012 12:28 PM #225
As of now, yes only 2 variants. I'm also waiting for the mid-range 4x2 A/T variant which should fall in the 1.5m price range.
- Aug 2012
- 36
- Jan 2007
- 43
September 19th, 2012 01:46 PM #227
- Sep 2012
- 7
September 19th, 2012 04:14 PM #229below are the specs that were provided to me by a chevy SA yesterday. i happened to visit the chevy main office in buendia yesterday and it so happened that the SA's were undergoing a training for this trailblazer. i wanted to scrutinize their unit but it was at the basement and kind of dark..
looks like these specs are an early release and there could be minor corrections (like the size of the spare tire for the 2.8 variant).
also need to discuss these specs with the chevy agent to better understand it (like Handle assists - does this refer to the hill start assist and hill descent control?)
(p.s. apologies for the archaic method of posting the specs, i dont know how to post a pdf file. just a newbie here )
SPECS (part 1):
Trailbalizer MY13 Specification Trailblazer 2.8 4WD AT Trailblazer 2.5 2WD MT
Engine
Engine Diesel, 2.8L, DI, L4, DOHC Diesel, 4 Cylinders, 2.5L, DI, L4,DOHC
Displacement (mm) 2776 2449
Turbo Charger VGT (variable geometry turbo) FGT (fix geometry turbo)
Output (kw/hp * rpm) 132/177 * 3,800 110/148 * 3800
Torque (Nm/lb-ft * rpm) 470/347 * 2000 (AT) 350/258 * 2000
Bore and Stroke (mm) 94 x 100 92 x 94
Cylinder Head Material - Cast Iron Standard Standard
Emission Sytem Euro 2 Standard Standard
Transmission 6 speed - AT 5 speed - MT
Shield Transfer Case Switch type Electric Shift NA
Suspension System
Soft Ride Suspension System Standard Standard
Front Suspension Independent Short Long Arms Independent Short Long Arms
Rear Suspension 5 link with coil spring 5 link with coil spring
GVW RATING - (lbs/kg) 6,060 lbs / 2,750 kg 6,060 lbs / 2,750 kg
Steering System
Power Steering Type Non-variable ratio Non-variable Ratio
Turning Radius (m, curb to curb) 6.35 6.35
Steering Column Lock Control and Tilt Type Lock Control and Tilt Type
Brake System
Front Brake Vented Disc Brake Vented Disc Brake
Rear Brake Solid Disc Brake Solid Disc Brake
Hand Brake Chrome Black
Front Caliper Cast Iron, Dual Piston Cast Iron, Dual Piston
Rear Caliper Cast Iron, Single Piston Cast Iron, Single Piston
Tire and Wheel
Tires 265/60 R18 245/70 R16
Spare Tire 245/70 R16 245/70 R16
Wheel Alloy Wheel 18" x 7.5 J, Alloy Finishing Alloy Wheel 16" x 6.5 J, Alloy Finishing
Pitch Circle Diameter 6 x 139.7 mm lug 6 x 139.7 mm lug
Wheel Spare 16" x 6.5 J, Steel 16" x 6.5 J, Steel
Dimension
Length (mm) 4878 4878
Width (mm) 1902 1902
Height (mm) 1848 1848
Track Front/Rear (mm) 1570/1588 1570/1588
Curb Weight (kg) 2091 TBD
Fuel Tank Capacity (L) 77 77
Maximum Towing Capacity 3000 TBD
Exterior
Fenders - Front Integrated/Stamped Molding Integrated/Stamped Molding
Molding Side Window Chrome Black
Rear Window Defogger - Electric Standard Standard
Knob - Transfer Case Control Lever Chrome Silver Insert
Electronic Cruise Control Standard NA
Handle O/S Door - Body Color Chrome Strip NA
Handle I/S Door Glossy Chrome Porthos Grey
LH & RH Rearview Mirrors Electric, Power Fold & Turn Signal IND, Electric, Manual Folding & Turn Signal,
Chrome with Remote Control Color with Remote Control
Front Bumper with Round Fog Light Chrome Insert Gray Insert
Side Steps Running Board Standard Standard
Front and Rear Mudflaps - Formed Standard Standard
Low/High Beam Headlamp Function Projector Halogen
Front and Rear Fog Lamp Standard Standard
Headlamp Leveling System - Control Standard Standard
Tail Stop Lamp Led Bulb
Windshield Wiper Standard Standard
- Sep 2012
- 7
September 19th, 2012 04:14 PM #230SPECS (part 2):
Interior
Instrument Panel - Dash Grey Standard Standard
Interior Molding I/P Athos Beige Porthos Grey
Filter - Pollen Standard Standard
Shift Cover Athos Beige Porthos Grey
Steering Wheel Leather Wrapped Deluxe
Seat Trim Shale - Leather Very Dark Ash Grey/Shale - Cloth, Struct
Driver & Passenger Pocket Standard Standard
Rear Seat Armrest Standard Standard
Pocket - Front Seat Back Standard Standard
Molding Door Interior Athos Beige Porthos Grey
Interior Trim - Shale Standard Standard
Door Panel - Shale Standard Standard
Door Trim Vinyl, Meridian Cloth, Truss
Roof Beige Console Standard Standard
Driver & Pass Mirror w/ Illumanation and Cover Standard Standard
Power Operated Window, driver express up/down Standard Standard
Lamp Center - Dome Standard Standard
Driver's Information Instrument Display Standard Standard
Speedometer Standard Standard
Instrument Cluster Color Blue Black
Safety and Comfort
FR & RR A/C HVAC System Automatic Climate Control Manual
Rear Seat - 40/60 Split, Folding Standard Standard
3rd Row Seat-Folding Standard Standard
Driver's Seat Adjuster Power, Multi-directional/Functional Manual, two way
Handle Assists Standard Standard
Radio - AM/FM Stereo, Seek/Scan, CD,
ETR, Clock, DSP, MP3?WMA, 2Din, RDS Standard Standard
Steering Wheel w/ Radio and Rebundant Controls Standard Standard
Speaker System 8 - Premium 6 - Base
Radio Antenna Standard Standard
Windshield Style - Shade Band Standard Standard
Restraint System - Airbag Module Standard Standard
ABS Standard Standard
Electronic Stability Control & Traction Control Standard NA
Child Restraint Provision Standard Standard
Head Restraint - RR Seat Leather Covered Cloth Covered
Remote Lock Control Standard Standard
Driver's Fuel Filler Lock Control Standard Standard
Immobilization - Security System Standard Standard
Electrical Theft Deterent Standard Standard
Rear Park Assits Sensor Indicator Standard NA
Seat Belt Warning Alarm Standard Standard
Xiaomi E-Car
