Page 63 of 69 FirstFirst ... 1353596061626364656667 ... LastLast
Results 621 to 630 of 684
    May 2007
    #621
    Hello. Need your advice. Im in a quandary on whether to buy a second hand 2014 spin gas 1.5 a/t unit. Im just worried about the maintenance and availability of parts when in case a problem arises. But im seriously considering in. Hope to hear from anybody. Thanks
    #622
    ^^Matagal na wala ang spin dito sa market, around 2 years na ata if i'm not mistaken. The reason? It was overshadowed by its opponents when it comes to sales. What's more is that you dont get to see at least one of these plying the routes everyday. Maybe just rarely and with that, you know what it means. You've guessed it.
    Btw, is this your 1st time purchasing a vehicle? If so, then i suggest you look for competing models of other brands instead. An avanza or mobilio is better because both toyota and honda have good aftersales support. However, if you dont want those two, then try to look at the ertiga, though i'm not sure abt. suzuki's aftersales... Good luck.
    May 2011
    #623
    Bakit nga tinanggal sa market itong spin? When it was freshly launched marami naman ako nakita sa daan.
    Sent from my SM-G930F using Tapatalk
    #624
    Quote Originally Posted by 3GEMS View Post
    maybe the manufacturer decided, they had too many models competing for the same market?
    May 2007
    #625
    Thank you for the feedback. Not the first time naman. I'll just other brands and models.
    #626
    Diba may bago din ang chevy, which is yung trax ata? Baka yun yung pumalit sa kanya kaso yung nissan juke at honda hrv ata katapat nun eh.
    Quote Originally Posted by hops View Post
    No problem. Read other threads of other models too and backread ka lang. You can learn additional information about them from reading it.
    Mar 2004
    #627
    Avoid Chevrolet ... stick with Japanese if buying used and not so well versed with cars ...
    Mar 2004
    #628
    Chevrolet Spin is a 7 seater ... Chevrolet Trax 5 seater and a subcompact crossover ... which is priced similar to a Subaru XV ...
    #629
    I just read somewhere na yun daw ang ipinalit nila sa spin sa other countries. Kaya naisip ko rin na it may be one of the reasons why na phased out na ang spin in the local market.
    #630
    Stay away from Chevy if you don't have experience on high cost and scarcity of parts.
    Rad fan motor is making some noise and have to go to the usual dramas in claiming to TCCI. Stupid thing with the instrumentation is that it doesn't have temp gauge to warn from overheating.good thing I have scanguage to monitor water temp.
    I recently stripped the stud bolt and have to source parts, found out tbz and colorado shares the same rear and front studs which is cheaper than buying the original part number for spin. I have yet to check the crosswind/mux stud if it does fit which is much cheaper.
2012 Chevrolet Spin
