Results 1 to 12 of 12
    May 2008
    Saan pwede magpapalit the belt/webbing ng seatbelt. Frayed nayung tabi at sumasabit na sa retainers. Not sure where to post this inquiry. Admin kindly move/repost if incorrect.
    Thank you.
    Model and year of said vehicle?
    May 2008
    Corolla 7th gen acquired October 92. The plastic pillar trim of corollas in this era have sharp edges. Newer models have rounded edges. The seatbelt rubs against this edge as it is pulled out and retracted which subsequently caused the fraying of the edge. i am hoping to locate an upholstery shop that sells the belt material by the meter so that i can just replace the belt and retain the retractor mechanism and buckles. It is easy to remove the belt from its spool, have the ancillaries transferred and sewn on the new belt using the original belt as a template. Cost of surplus units will also have to be considered against material, if even available, and sewing labour.
    Quote Originally Posted by goldrat View Post
    work on the sharp-edged trim, so's the sharp edges get rounded?
    May 2008
    Check out "Safety Restore" and "Seat Belt Webbing Replacement" videos on youtube.
    Thank you.
    try mo sunugin yun part na may problema, pag ayaw talaga tsaka mo palitan
    i am curious,
    "why did they get this frayed in the first place?"
    errr...
    puedeng palitan yang belts, 'di ba?
    i thought i saw them hanging in the cathay centers in evangelista.
    yup pwedeng pwede
    parang interchangable pa nga e kasi pwede mo palitan yun dulo
    yup pwedeng pwede
    from what i see,
    it would seem, the belt and the inertia reel at one end, comes as a set.
    the other end naman, is industry-standard and probably would not need replacement.
    so, replacement would require only the correct-size wrenches.
    good watch!
    but,
    if we plan to remove the belt from the reel, to replace only the belt,
    we have to be sure FIRST, that we have a replacement belt.
    yung mga nakita ko kasi, assembly ang binebenta nila.
    however,
    if post-er is amenable, he can simply rotate his current belt, so that the frayed side will now be pointing to the other side, and the un-frayed side will be the one rubbing against the retainer.
    Get the cheapest orig 2nd hand sa surplus shops in Evang, Banawi, Blumentritt.
seatbelt
