Saan pwede magpapalit the belt/webbing ng seatbelt. Frayed nayung tabi at sumasabit na sa retainers. Not sure where to post this inquiry. Admin kindly move/repost if incorrect.
Thank you.
Thank you.
yup pwedeng pwede
parang interchangable pa nga e kasi pwede mo palitan yun dulo
Seatbelt Replacement - YouTube
How to remove a seatbelt from its reel - YouTube
good watch!
but,
if we plan to remove the belt from the reel, to replace only the belt,
we have to be sure FIRST, that we have a replacement belt.
yung mga nakita ko kasi, assembly ang binebenta nila.
however,
if post-er is amenable, he can simply rotate his current belt, so that the frayed side will now be pointing to the other side, and the un-frayed side will be the one rubbing against the retainer.
Get the cheapest orig 2nd hand sa surplus shops in Evang, Banawi, Blumentritt.
Corolla 7th gen acquired October 92. The plastic pillar trim of corollas in this era have sharp edges. Newer models have rounded edges. The seatbelt rubs against this edge as it is pulled out and retracted which subsequently caused the fraying of the edge. i am hoping to locate an upholstery shop that sells the belt material by the meter so that i can just replace the belt and retain the retractor mechanism and buckles. It is easy to remove the belt from its spool, have the ancillaries transferred and sewn on the new belt using the original belt as a template. Cost of surplus units will also have to be considered against material, if even available, and sewing labour.
Check out "Safety Restore" and "Seat Belt Webbing Replacement" videos on youtube.
