Results 1 to 2 of 2
July 24th, 2007 03:51 PM #1
mga sir... based dito sa pic ng alarm module ko, san po ba ko dapat magtap ng bypass switch para pwede ko i-off/disable manually yung alarm ko if ever mawala yung remote,magmulfunction, etc... bihira ko rin kse gamitin yung car kaya advantage na rin na pwedeng i-disable yung car alarm para hindi madischarge yung battery. thanks....
July 25th, 2007 10:53 PM #2
the best u can do is itrace mo na ung hidden valet switch (micro push button switch or toggle type switch) start ka dun sa wire connection na ang label e ARMED, try mo din trace ung F.BR, NG, H.BR kung san nagpunta or connection.
isip ko lang pambihirang alarm yan kung walang valet sir.
3 types to manipulate valet switch (pag may nakita ka sir):
1) push on valet switch until mag steady light ung LED at ignition ON
2) flick toggle switch at ignition ON then LED turns to steady lyt
3) kung coded push on switch (plainview valet switch)yan patay tyo jan may code yan sir (like clifford alarm sys.)
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
