Results 1 to 9 of 9
    Pips,
    Nagloko yung alarm ko eh. Ayaw na tumigil. Naka-engage lagi kapag ni-lock ko yung kotse. Baka may way to override this. Tinanggal ko na lang muna yung battery.
    Check mo yung mga 'abang'. Yung door switches and hood/trunk pin switches (if equipped). Minsan yung hood pin kasi medyo low quality ang kinakabit.
    Sep 2006
    This can also be a sign of a failing battery..
    Had it checked already. The brake switch was grounded. Got it fixed already. Ayos na ulit!
    Aug 2005
    possible din ang remote .
    Nov 2006
    mga bossing pa tulong nmn po...ung venom alarm ko po di na gumagana ng maayos...lock at unlock nlng po ang gumagana pero wala nang sound...kahit po panic button hindi na po gumagana...nag palit lng po ako ng glow plug...and all of a sudden nawala na ung alarm...ano kaya ang solusyon dito??salamat po
    medyo ot lang pero i have a similar problem w/ my code alarm. the unit itself is still ok but the 2 remote commanders are already iffy. pwede kaya palitan iyong mga remote lang?
    Quote Originally Posted by dyipi View Post
    nagalaw ang valet switch. nakalagay yun usually sa ilalim ng manibela or taas ng brakes. ordinary switch lang ang itsura. lagay mo sa on position yung ignition key then toggle the switch and remove the key. this should be done not more than 15 seconds ata. basta mabilis. if this does not solve ur problem dalhin mo na lang sa banawe.
    palit ka muna battery ng remote. baka mahina na. meron nabibili na remote sa banawe, medyo mahal nga lang.
Venom Alarm Problem
