Results 1 to 9 of 9
September 27th, 2006 10:18 AM #1
Pips,
Nagloko yung alarm ko eh. Ayaw na tumigil. Naka-engage lagi kapag ni-lock ko yung kotse. Baka may way to override this. Tinanggal ko na lang muna yung battery.
September 27th, 2006 01:02 PM #2
Check mo yung mga 'abang'. Yung door switches and hood/trunk pin switches (if equipped). Minsan yung hood pin kasi medyo low quality ang kinakabit.
September 28th, 2006 03:32 PM #4
Had it checked already. The brake switch was grounded. Got it fixed already. Ayos na ulit!
Toyota is my choice
- Aug 2005
- 2,063
- Nov 2006
- 15
February 16th, 2007 03:08 PM #6mga bossing pa tulong nmn po...ung venom alarm ko po di na gumagana ng maayos...lock at unlock nlng po ang gumagana pero wala nang sound...kahit po panic button hindi na po gumagana...nag palit lng po ako ng glow plug...and all of a sudden nawala na ung alarm...ano kaya ang solusyon dito??salamat po
February 16th, 2007 03:28 PM #7
medyo ot lang pero i have a similar problem w/ my code alarm. the unit itself is still ok but the 2 remote commanders are already iffy. pwede kaya palitan iyong mga remote lang?
- Mar 2006
- 83
February 25th, 2007 02:10 AM #8nagalaw ang valet switch. nakalagay yun usually sa ilalim ng manibela or taas ng brakes. ordinary switch lang ang itsura. lagay mo sa on position yung ignition key then toggle the switch and remove the key. this should be done not more than 15 seconds ata. basta mabilis. if this does not solve ur problem dalhin mo na lang sa banawe.
- Mar 2006
- 83
February 25th, 2007 02:12 AM #9
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
