Results 1 to 17 of 17
    Nov 2007
    Hi sirs/madams.
    I had a TVSS alarm installed in my ride (Vios G) and would like to adjust/increase its sensitivity. Where and How can i do this?
    One of d tsikot member at our Vios thread said that it can only be done at d casa. Are there any of u guys who can possibly provide an input as it is time consuming to bring back d unit at d casa just to have it adjusted. Not to mention the long queue at the service section of toyota.
    Another question, at one instance i used the remote of d alarm to lock d car then used d key with transponder to unlock d car. The alarm was triggered and did not stop until i used d remote of d alarm to unlock it. By the way, nabuksan nman nung transponder key yung kotse yun nga lang nag full alarm cya.
    I'd like to post the pics of d transponder key and d remote of d TVSS for reference purposes but i cant seem to find the button in this tablet to do such thing.
    Your inputs are greatly appreciated.
    Nov 2007
    Anybody?
    1st question, yun din narinig ko, toyota will adjust it pero last time i heard, mas mahal yung adjustment nila kaysa pakakabit ka na lang ng bagong alarm. and i have no idea bat napakamahal ng adjustment.
    2nd question, ganun talaga behavior ng alarm, one said that to turn off alarm, you have to turn the ignition key on (acc mode) and off 7 to 10 times. i havent tried it though.
    Nov 2007
    Thanks for d reply sir.
    Fortunately for me, both are for free courtesy of my SA.
    Jun 2013
    i think you can't increase the sensitivity of any alarm until you buy a new one with high range and sensitivity.And when you unlock the car most of the time the lock sensor will not work after you unlock that with fob and the light flashing with that some time.
    Jun 2013
    Quote Originally Posted by Albert25 View Post
    For more information about the security
    Security patrol, mobile patrol, security patrol services
    Nov 2007
    Had it adjusted na nga pala for free when i had my pms. Mas naging responsive na nga cya ngaun.
    Quote Originally Posted by Excalibur View Post
    Saang casa yan boss? Sabi bicutan ala daw sensor tvss. Vios g ako.
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Nov 2007
    Quote Originally Posted by brainmafia_310 View Post
    Pasig po sir. Same here G variance din.
    So pagtinamaan na sya nag aalarm na boss? Like ung usual na alarm system? Pagnaglock ka ba ng kotse using remote may tumutunog? 1.3g pala vios ko baka iba sa 1.5g.
    Mar 2013
    brad ano ibig mo sabihin na mas naging responsive sya? vios 1.5g AT saken,, nagpalagay pa ko ng separate alarm.
    me shock sensor ba ang Vios naten? ang alam ko kase nag aalarm lang sya pag binuksan mo gamit yun susi or binasag yun salamin/force entry.
    Jul 2013
    hi guys, sorry if it's a newbie question...
    i have the tvss installed in my new vios j. the remote has 4 buttons (lock, unlock, then a mute-i think and a bell). how do the two last buttons work?
    1. lock button - locks the car (you will hear a beeping sound and blinkers that confirm the action)
    2.unlock button - same as above
    3. --- how does that work? what does it do?
    4. when i press it, it alarms the car, so i press the unlock button to stop it. (but i dont know if it's activated or not).
    patulong naman pls? thanks!
    Jun 2006
    May autolock ba tvss alarm ng vios g nyo? Sa innova tvss ko , when i reach 30, mag autolock na doors. Dito sa vios wala. I have to manually close the locks pa.
    Quote Originally Posted by shibby75 View Post
    wala po sir. pero baka pede iactivate.
    anybody who tried this?
    Feb 2007
    On my fort, it automatically lock after 20 to 30 secs if you unlock it but did not open the door. As my understanding, tvss dont have shock sensors as standard option. They only alarm if the doors were opened when armed. Keyless entry lang yung remote ng tvss. Try to kick your tires or yugyugin nyo cya if it will alarm. Tvss can also be upgraded (depends on the model i guess) adding shock sensors and other modules like tilt sensors, pressure sensors, window ajar, etc. c/o Code Alarm.
    Sent from my Samsung Galaxy S4 using Tapatalk 4
    Aug 2006
    Sadly, wala na yung auto locks sa new Vios 2013, even when I inquire this sa TMBC, sabi nila talagang wala na daw even on new Prado.
    Aug 2008
    my 2nd gen vios doesn't have an autolock feature and shock sensor. i can live without the autolock feature but i can't without the shock sensor. hence, i bought an alarm module to upgrade the existing TVSS (without additional remote and using the OEM key fob).
    we have a 2012 Innova G, aside na nag-aalarm siya kapag open ang door at hood, nag-aalarm din siya every new year. so i guess, meron siyang shock sensor.
TVSS Alarm system question
