Results 1 to 20 of 20
    Sep 2016
    Hi. First of all, apologies for reviving this old thread. Yung query ko po kasi is regarding din po sa subject mismo.
    I would like to know sana if meron sa inyo na nagkabit ng speed sensing door locks recently lang? San po kayo bumili? Kotse po pala namin is Mobilio old model. Yung TOTL variant kasi alam ko may kasama na speed-sensing door lock na. Yung V model kasi wala. Thaknks po.
    Nov 2003
    Same here, i am looking for a speed sensing door lock for my City 1.5E. Saw one at Lazada but it's from abroad. is there a local supplier,
    https://tinyurl.com/y8p26srj
    but does the ecu support it?
    my guess is, "yes".
    but ask around first, to be sure.
    Nov 2003
    my guess is, "yes".
    that is also what i was thinking, in case it's not supported will it damage the ECU ?
    Quote Originally Posted by sneaky41 View Post
    i do not think so. the ecu will probably not even know, that you installed one.
    you might not even be able to connect its electricals.
    but ask first, sir. hinala ko ay puede. you just have to find the electrician who knows how to connect it.
    Nov 2003
    thanks. will definitely ask around.
    Jan 2019
    Reviving Thread lang po uli hehe
    Regarding po sa speed sensing door lock nagkapag ipainstall po ako and it works fine ngayon po ung nag palit ako ng battery key fob cant lock the power lock but can unlock it, nawala na din po yung speed sense lock? any ideas po kung ano yung problem?
    Sent from my CPH1937 using Tapatalk
Speed Sensing Door locks
