Results 1 to 11 of 11
    Aug 2013
    hi,
    just bought a mirage G4 GLS and
    need your advise po on below:
    1. pwede ba lagyan ng rear view camera ang G4 and san pwede ipalagay and ano brand ang maganda at a reasonable price. if ever ipa install sa labas will it void yung casa warranty? yung monitor ba nito will be another/separate screen or ico-connect nalang sa existing screen sa me dashboard?
    thank you
    Sent from my iPod
    Aug 2012
    yes. sa bumper, drill-hole type. or sa license plate, bolt-on type.
    i use a China-made camera. more than a year na and still working. costs P1,500 in Banawe with 1 year warranty. connected to Pioneer AVH-1450DVD head unit.
    if you want branded cameras, you can buy Pioneer, Sony, Kenwood, Panasonic, etc. these costs more, from P5,000 and up.
    warranty will only be voided if problem/damage is caused by the added part. para sure ka, call the CASA before you install anything.
    meron model na may kasamang separate screen. meron model na camera lang. if may AV INPUT ang stock screen mo, then pwedeng camera lang ang bilhin mo.
    Mar 2004
    ^^^ Yes you can install reverse camera and connect it to the existing head unit. Best to get the model that can be mounted above license plate, it gives a better view compared to the bumper type camera plus you don't need to drill a hole. These cost about P2000. Try MASPRO in Banawe.
    Warranty won't be an issue. If it becomes an issue, you can always have it removed before claiming warranty.
    Aug 2012
    note that the newly designed LTO license plates will use LTO security locks. this could pose an issue with cameras that install on license plates (bolt-on type).
    Mar 2004
    ^^^ The reverse camera is not bolted onto the license plate, it's installed beside / between the license plate lights.
    Aug 2012
    in that case, that should be okay.
    but i'm referring to cameras directly installed onto license plates using license plate bolts.
    Aug 2012
    this should be okay..
    Aug 2011
    I went to winterpine. It will cost 6k less 10% yung back up camera nila for mirage and g4..
    Posted via Tsikot Mobile App
    Aug 2013
    thanks sa inputs mga bossing.
    another thing nga pala, hindi b madali manakaw yung camera either bolt in or drill type? madalas kc nag papark ako sa kalye or sa tapat lang ng mga establishments.
    * tj abs
    san yung winterpine? ano brand and ok kaya resolution lalo n sa gabi. thanks
    Sent from my iPod
    Aug 2011
    Boss sa araneta ave malapit sa sm centerpoint. Avt ang brand niya pero pede din ibang brand kasi jack lang naman ang ikakabit sa likod ng avt head unit natin.
    Aug 2011
    7164831 winterpine araneta. Call niyo lang sir. Sila ang authorized distributor ng accessories ng mitsubishi. Mahal sa casa
rear camera for Mirage G4
