Originally Posted by
indiej
try this
from autopage manual for rf225
Alarm Feature “I” Programming:
1. Turn the Ignition 'switch ‘ON/OFF’ 3 TIMES and stay in 'OFF' position.
2. Push the Valet switch 2 times and hold in on the 2nd push. When a long chirp is heard, release the valet switch. You are now in the Alarm feature ‘I’ programming mode.
3. Press the transmitter button corresponding to the feature you want to program.
a. The factory default settings is always 1 LED flash, 1 chirp.
Depress the disarm button once for auto rearm off (factory), there'll be one pulse notification
twice for auto rearm on, there'll be 2 chirps
then try the exit by turning to ignition 'ON' position instead of waiting 15 seconds. 3 long chirps will confirm exit.
test by making sure all doors, hood, trunk are closed and the key is off. HtH
