Quote Originally Posted by indiej View Post
try this
from autopage manual for rf225
Alarm Feature “I” Programming:
1. Turn the Ignition 'switch ‘ON/OFF’ 3 TIMES and stay in 'OFF' position.
2. Push the Valet switch 2 times and hold in on the 2nd push. When a long chirp is heard, release the valet switch. You are now in the Alarm feature ‘I’ programming mode.
3. Press the transmitter button corresponding to the feature you want to program.
a. The factory default settings is always 1 LED flash, 1 chirp.
Depress the disarm button once for auto rearm off (factory), there'll be one pulse notification
twice for auto rearm on, there'll be 2 chirps
then try the exit by turning to ignition 'ON' position instead of waiting 15 seconds. 3 long chirps will confirm exit.
test by making sure all doors, hood, trunk are closed and the key is off. HtH
Thank you sir!
Actually that's the same way I was doing all along and it was not working still.
What I did is that I brought it back to the installer in araneta ave and we found out the culprit and it was weird! After we have the alarms installed nicely on my car, we fixed my dome light problem on my revo and have it replaced with two 36 led bulbs on my car. I have 2 dome lights kasi using just the old stock bulbs. It was conflicting since sometimes my alarm would have 3 chirps instead then later 2 chirps then will be back to 3 chirps again.
What we did is that we tried removing the new LED's on the dome lights and tada! It's now working ok! No more auto passive door locking on my car but minus now the very bright lights inside my car which my sister can even do her assignments inside it lolz! The installer said that the led's for dome lights uses some certain conflicting polarity which they first encountered on a HONDA Accord daw when they installed an alarm on it. This is the 2nd time they encountered this kind of trouble in installing alarms conflicting with an installed led's on a dome light. I opted to use a lesser led bulb say 12 led bulbs instead of the 36 bulbs I used. They advised me to just stay away from it and just to stick with the stock dome bulb and just have it cleaned from time to time. Sayang I miss already the very bright lights on my cockpit hehe. It was just weird thingking how the led dome lights can affect your alarm system inside your car. Anyone has the same experience like mine?
