Results 1 to 18 of 18
    Aug 2005
    maybe ung AGC means "at alarm armed w/d ground connection" kaya pwde rin maglagay ng starter kill relay d2, pero wala ka nakitang relay jan dba? trace mo lang muna sir
    Aug 2005
    kompleto pla label mo, ung label na ST0 n ST1 ang starter kill
    Aug 2005
    ingat lang sa wire na IGN, GND at B+
    Nov 2006
    sir pano gagawin ko? short ko lang yung ST0 and ST1 then turn the ignition on? what about the AGC? ano gagawin ko dun?
    thanks...
    Aug 2005
    remove the wiring harness sa alarm module trace mo muna ung STO n ST1 pag ang end wire nya e nka top sa same color na wire sa wring harness under ng steering collum sa may ignition switch, makikita mo naman un na pinutol nla ung wire at sa ST0 and ST1 nila knabit. go for it na connect muna ST0 n ST1 and cover muna ng electrical tape and it should be tight ang pagbond mo nung wire.
    start the engine!
    if ever na hindi ka cgurado sa gagawin mo at dmo masyado magets ung cnabi ko, kung manual tranny ESi mo sir ito gawin mo remove alarm module then turn ignition key to ON position at magpatulak kana kadyot start ba at dalin mo sa nearest electrician na kilala mo.
    Aug 2005
    pwede rin PM me ur landline at col kita sir
need urgent help!! my remote isnt working..
