Results 1 to 3 of 3
August 14th, 2011 09:34 PM #1
tsikoteers,
ask lang po...yung lights ko kasi,nawala kapag nag-on or off ako ng alarm?ano kaya possibe reason at nagkaganun?even pag nag-oopen ako ng doors, di na automatic na naghahazard kagaya dati..pero gumagana nman ang hazard light pag ino-on ko...nawala lang yung link nya sa alarm..thanks in advance!!!
August 15th, 2011 12:13 AM #2
if may fuse galing sa alarm papunta hazard/signal lights pwede busted na yung fuse. try to listen also near the alarm module kung nag switch yung relay that turns on/off yung signal lights.
August 15th, 2011 03:23 PM #3
high idle RPM at engine start
