Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Hi mga Sir, saan ko po ba pwede paayos yung isang remote nung alarm/ keyless entry ko.
    Nung una pumapalya lang sya, sinusumpong, until hindi na talaga sya gumana. akala namin battery ang problema.
    Nagpunta kami sa concorde kung san sya binili, binuksan nung tagaduon tapos napagana nya, hindi naman pala battery ang deperensya.pero ilang gamit lang ganun nanaman...
    Ano po kaya problema??
    baka yung contact ng battery ang may problem. linisin yung contact.
    subukan ko po sir...maraming salamat
    Quote Originally Posted by pdx View Post
    in my experience...
    the battery isn't terribly expensive.
    just replace it, po.
    and clean the contacts in the process.
    i equate "dirty contact" to weak batteries. (how can the contact get dirty in there?)
    Baka yun contact kailgan mo I bend palabas, na flat na siguro
    in my experience...
    that's what i was wondering... paano madudumihan yun eh sarado yun? and i'm not sure about the battery... kasi bihira naman magamit yun.. yung key na may problema is yung laging nakasabit sa sala. nagagamit lang sya tuwing wala ako at nasa work (im working abroad nga pala - 1 month away then 1 month at home). Yung madalas kong gamit na susi nasa drawer lang sa kwarto pag nasa work ako. nagagamit lang yung isang susi pag pinagddrive ng in-law ko yung mag-ina ko pag may lakad sila. so paano hihina yung battery nya??
    try ko na lang po linisin yung contacts as per your advise. may nabili na din akong battery nung nagpunta kami ng concorde, ikakabit ko na din para sure.
    salamat po mga sirs!!
    my suspicion is, the battery slowly leaks and the chemical acts on the metal contacts. the amounts involved are so small, we do not notice them when we inspect them. but when we wipe them batteries and contacts clean, the electrical connection is restored.
    tama yung tao.. madumi nga ang contact. but it will keep on recurring, until the offending battery is replaced by another one that does not leak at all.
    Thanks Doc, gawin ko po yan pagkauwi ko. marami pong salamat!!
    Mar 2016
    ask lng ung sa GS ng kuya ko! kapag ng lock unlock ka first try ok nmn kapag inulit 2nd 3rd parang nalolowbat ung ibang pinto hindi nagana?kadalasan ung driver's door! saka ung isang sliding door ayaw n tlg! manual nalang...posible problem nun? bago battery...kaya imposible bat. thanks
    Quote Originally Posted by GrandStarexTci View Post
    hindi siguro low bat yan. all the doors' actuators get electricity from the car's battery. if the battery were that weak, you won't even be able to make the starter solenoid click.
    kung low bat naman yung susian, ay lahat nang pinto ang hindi magsasara o mag-bubukas.
    hinala ko... wear and tear ng actuators... or loose connections.
    happy trouble-shooting.
    Sep 2016
    good day dr.D, I'm also been having problems with my keys and doors for the past month, 1st the key remote is always malfunctioning and doesn't work most of the time so i have to manually lock the doors of my starex crdi grx 2006, what can be the problem & the solution? , 2nd every morning when i walk out to check my starex i noticed the doors are sometimes already unlocked, this happens several times already but i always lock my doors manually before leaving. Could this be also an effect of the malfunctioning key remote? Fortunately i live in a secured & safe village neighborhood so nothing is lost or damage inside my van.
    Hoping for your expert opinion regarding this matter. thanks alot
    Oct 2013
    aftermarket alarm key fob ba yan?
    worn out button switch
    Apr 2013
    I lost my car lock remote!!! Narereplace po ba yung remote lang? O Kailangan na palitan yung buong system? Additionally, pag po ba nireplace yung central lock system, pati alarm papalitan din?
    Sep 2012
    Quote Originally Posted by archielew View Post
    Depends... kapag swerte ka pwedeng control module and remote lang papalitan that will cost you around 2k
    Sent from my ASUS ZenFone 4 using Tapatalk
    Apr 2013
    Quote Originally Posted by jodski View Post
    Ouch. Thank you for the info.
    yes, it depends.
    if the system is an aftermarket installed by the casa or banawe, baka meron.
    but if the system was installed as part of the package in the factory...
    "puede, but it will cost you something like 10K, as we will have to contact the factory and order a replacement..."
    recommend ni SA sakin, kabitan na lang ng aftermarket.
    Apr 2013
    yes, it depends.
    sounds good. Winterpine installed it so must be good. thank you
    May 2018
    hi mga boss. ask ko lang po, bigla kasi nawala yung horn honk ng remote lock ko ng civic 2004 dimension, paano po ba ibalik yung horn honk sa default pangalawang pindot mo ng lock sa remote.
    at ang warning beep like sa seatbelt ko po ay nawala din. pls help... tnx...
    Mar 2004
    Have your car battery checked ...
    May 2018
    the battery is ok boss, lahat gumagana except yung remote lock horn honk lng nawala...
Keyless entry remote control problem
