Results 31 to 40 of 102
- Apr 2015
- 40
April 18th, 2015 09:04 PM #31Bale sir ija-jumper ko yung white (to starter) at red (to ignition switch) para mabypass ang relay? Yun lang ba sir ang gagawin?
- Oct 2013
- 1,181
- Apr 2015
- 40
- Apr 2015
- 40
April 18th, 2015 09:30 PM #34wala bang masisira sa sasakyan sir kung i-bypass ang relay? Pare-pareho lang ba sir ang kulay ng mga wirings papunta sa starter (white) at sa ignition switch (red)?
- Mar 2014
- 901
April 18th, 2015 09:38 PM #35Wala bang redondo ng starter pagpihit ng key sa start?
Sent from my Starmobile UP+ using Tapatalk
- Oct 2013
- 1,181
April 18th, 2015 09:41 PM #36Check mo kung parehas ng color coding, anyway, basta yung wire papunta starter, typical malaki diameter nyan. Kung makita mo na yun, alisin mo relay at i-connect mo na lang.
Hanap ka na lang car electrician dyan.
- Apr 2015
- 40
April 18th, 2015 09:59 PM #37opo sir walang redondo ng starter pagpihit ng susi mula sa ON position papunta sa START position. Anong ibig sabihin pagganun sir?
- Mar 2014
- 901
April 18th, 2015 10:06 PM #38Nasabi mo ayaw na gumana car stereo mula ikabit balik mo battery.
Check mo muna fuse sa ilalim dashboard mo para sa car stereo. Baka putok na fuse nun, at ayaw rin mag-supply ng power sa relay(starter kill).
- Apr 2015
- 40
April 18th, 2015 10:16 PM #39Ok sir rodetor icheck ko bukas. Papano nga pala malalaman kung putok na ang fuse?
Pagnag oopen ako ng door ng car, nagbiblink ang headlight, signal light at backlight ng instrumentation (rpm, tachometer, etc). Ibig sabihin ba nyan sir ok pa ang battery ko?
- Mar 2014
- 901
April 18th, 2015 10:17 PM #40Kapag nag-disarm/unlock ng car alarm, na-deactivate yung starter kill, kaya pag-switch mo sa start ng ignition key, aandar starter motor mo.
high idle RPM at engine start
