Results 11 to 20 of 20
December 6th, 2012 05:51 PM #11
Try to check the central lock actuator first in your drivers window.
- Nov 2002
- 35
December 6th, 2012 07:53 PM #12What's your car bro? Is it an oem remote alarm/central lock system?
Had a problem with my corolla gli before with similar symptom as yours - using the remote the car respond with sound and flasher blink but won't lock/unlock even though the central locking is working when pressed from the driver side lock/unlock switch.
I did some tinkering on the alarm controller box and found one defective I.C. which was part of the circuit that triggers the lock/unlock switch. Circuit ok after replacing that part.
- Jul 2012
- 329
December 7th, 2012 10:58 AM #13honda jazz pare.. feeling ko oem remote/central lock system. nakita ko yung curcuit nya sa ilalim ng manibela kaso hindi ko naman alam panu ayusin.. hehehe! magkano yung IC? kaw ba gumawa or pinagawa mo nlng? need this done asap. may outing kami eh.. yoko nmn ipark yung car nang nagloloko at baka biglang bumukas yung lock at manakaw pa!
- Jul 2012
- 329
December 7th, 2012 11:02 AM #14nag work naman po yung central lock sa driver side kasi pag dun ko sinusian lahat nad unlock/lock... ganun din kpg nakasakay nko, pag yung sa driver side ang pinanglock/unlock ko nag respond naman lahat.
December 7th, 2012 02:24 PM #15
- 54,205
December 7th, 2012 08:00 PM #16just bring it to the fixit shop.. casa or banawe, etc..it looks like it's over your head..
my bet is the remote module somewhere in the car. either a loose connection, or it needs replacement in its entirety.
- Jul 2012
- 329
December 11th, 2012 01:58 AM #18stock po.. baka ipacheck ko na lang.. changing the alarm to a new one is not an option.. unahin ko muna gatas ni baby
- Oct 2012
- 102
January 26th, 2013 09:51 PM #19Baka reprogramming yan, dalhin mo sa casa. Before that read the Users manual, baka naka na disable lang. I had a similar problem with my innova, and I just read and followed the manual and got it to work.
- Sep 2006
- 84
January 28th, 2013 10:10 PM #20[QUOTE=nashimoto;2051957]dati po gumagana.. nag rerespond nmn ng tama yung lock sa remote.. gulat lang ako bigla nlng hindi na nag respond. nakikita ko yung nlock it's trying to "lock" pero hindi tumutuloy.. parang nahihirapan. separate po ba ang batt nung actual sa lock system sa batt ng remote? thanks mga sir]
defective na yang driver side motor/actuator hindi na kaya hilahin yung lock/unlock rod..just replace it with an aftermarket actuator it just cost less than P200/pc, yung may 5 wires kunin mo.
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
