Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Jul 2012
    mga sir need your help.. yung lock ng car ko wont work using the remote pero tumutunog naman at nakikita ko umilaw, it's just that hindi sya nag uunlock or lock kapag ginagamitan ng remote, i have to use the key. napalitan ko na batt ng remote. nag rerespond naman alarm kasi tumutunog using remote pero ayaw mag respond ng lock.. anu po kaya ang problema? laguna area po ako. thanks!
    Nov 2007
    Quote Originally Posted by nashimoto View Post
    Before, if you use your alarm "auto-lock" the same time you press your remote? If now it doesn't then it may be an electrical problem. Have a reputable car shop check on your alarm system.
    Oct 2011
    Baka ung sensor may problema, ung remote mo is not communicating with your car.
    Dec 2012
    This is common issue when circuit switch fuses. Just replace the switch allotted to central locking system, it will for sure. I have done with it.
    __________________
    Get paid more with delivery jobs
    Jul 2012
    dati po gumagana.. nag rerespond nmn ng tama yung lock sa remote.. gulat lang ako bigla nlng hindi na nag respond. nakikita ko yung nlock it's trying to "lock" pero hindi tumutuloy.. parang nahihirapan. separate po ba ang batt nung actual sa lock system sa batt ng remote? thanks mga sir.
    Mar 2012
    could be the central lock apparatus. baka busted na or loose yung rod connections.
    posible pong corroded na contacts ng relay sa loob ng alarm unit ...
    Jul 2012
    can i fix this alone or should i seek help from experts. naisip ko rin na baka nakaka affect yung driver side power window kasi nagloloko rin yun pag taas at pag baba nung window.. diba po dun yung main lock switch ng mga car?
    Mar 2012
    yup, magkalapit sila ng location.. if you've watched how it was installed or has any idea about it, or brave enough to try go DIY. But having it checked sa experts is a better option.
    Jul 2012
    mga sir just incase i decided to change the alarm system, ano po marecommend nyo ipakabit ko?
car lock not working using remote
