Results 11 to 20 of 20
- Oct 2013
- 1,181
- Aug 2012
- 104
June 22nd, 2017 01:41 PM #12Wala sir, yong wire lang kinabet sa cabin light ang pinalipat ko sa door switch may delay kc 10sec sa light kaya naging 3 chirps pag nilock
Sent from my GT-I9500 using Tapatalk
- Apr 2018
- 1
April 12th, 2018 04:57 AM #13Pwede po bang magask din about sa alarm system.new lang po akondto sa forum.ang car ko is mitsubishi adventure model 2017. Nabangga po ako from behind then namisaligned po ang clip sa likod sa back side so medyo bumaba sya konti then yung door parang ayaw nya tuluyang magclip though pag pinindot ko alarm nglolock naman sya.ang problema from then on mdalas n magloko ang alarm system.bgla bgla n lang sya magaalarm kahit sarado n mga doors.after few minutes magaalarm n naman.tpos napansin ko yung ilaw ng dashboard on the car laging naka on n sya.then today since 1am every now and then nag aalarm yung car.nung nagcheck ako.naisara ko naman sya maayos pero yung ilaw malapit sa susian nag rered then green.so kahit nalock ko na ulit lahat ng door nagaalarm n naman sya. May koneksyon po ba sya sa naging bangga ko? At need ko maipaayos yung pinto ko sa likod at yung n misaligned na prang bumper sa likod pra maglock ng todo yung pinto?.pahelp po nakakhiya n sa mga kapitbahay hatinggabi myat mya nagaalarm sya.
April 12th, 2018 09:36 PM #14
Temporary remedy is to disable the alarm. What's happening most probably is that since the door is misaligned, the sensor will detect that the door is open and so will trigger the alarm even though the door is closed.
Check the door, there should be a rubber like button that sends the signal if the door is open or not.
- Dec 2007
- 727
April 13th, 2018 02:46 PM #15
- Apr 2018
- 1
April 20th, 2018 05:39 PM #16Sir Good day. Ask lang po ako sir. I have a Mitsubishi Montero Sport 2013. Nakasanayan ko sir is 1 beep for unlock and 2 beeps for lock. After mag pa washing ako sir naging 1 beep na ung lock. Paano ko kay ibalik sa dati sir. Your advise is musch appreciated. Thank you
- 54,258
April 21st, 2018 01:52 AM #17i thought all the while,
it was one beep for lock and more than one beep, for unlock.
- May 2018
- 16
May 3rd, 2018 04:24 PM #18hi mga boss. ask ko lang po, bigla kasi nawala yung horn honk ng remote lock ko ng civic 2004 dimension, paano po ba ibalik yung horn honk sa default pangalawang pindot mo ng lock sa remote.
at ang warning beep like sa seatbelt ko po ay nawala din. pls help... tnx...
- Jul 2018
- 5
July 23rd, 2018 11:11 PM #19question lang mga sir, paano po ba iactivate yung alarm sa 2018 innova g. wala po kasi sound pag lock/unlock. salamat po
Sent from my SM-J730G using Tapatalk
- Sep 2012
- 8
July 27th, 2018 09:15 PM #20
Same here, ung Adventure 2011 ko, nag aalarm din sya bigla bigla. I think it all started when the fender liner at the left driver side wheel cracked/broken down. I also think there is a sensor in this side of the wheel, which usually got wet when there is a rain or flood or when I bring the car for a car wash. But even I replaced the fender liner the sensitivity of the alarm still there and the siren persistently sounds even during midnight. I already reprogram the alarm as stated in Mitsubishi Motors Auto Security Manual but to no avail. I have no choice now but to disarmed the security system.
How can I resolve this? Please help!
Nope Prius had variable speed/inverter Acs since its 2nd generation(~2004)....
A/c
