Page 15 of 17 FirstFirst ... 511121314151617 LastLast
Results 281 to 300 of 337
    Aug 2011
    #281
    mga sir, san po nabibili yung force alarm? or may binebenta si jameson? thanks!
    Aug 2011
    #282
    mavovoid ba warranty ko sa honda if papainstall ako ng force alarm kay jemson?
    Jul 2011
    #283
    Quote Originally Posted by jazzinmypants View Post
    There are shops in banawe that sells force alarm (the ones where jemson buys his goods). But IMHO, just let him buy and have him install it.
    Yes, it will void your electrical warranty (if you still have). But if you think about it, what on earth will happen to the electricals of your bnew? car
    Aug 2011
    #284
    sino may manual ng force car alarm? pls pm me. thanks
    #285
    kailangan ko din ng manual nito, baka meron kayo mga sir, paki e-mail na lang po. tanunoy*gmail.com TIA.
    Jan 2009
    #286
    mga sirs,
    naexperience nyo ba ito sa force nyo? yung samin kasi biglang nawala yung sound ng alarm. pero gumagana pa naman.
    thanks!
    Jan 2009
    #287
    I'm not sure about the GD (other GD owners can chime in). Nabenta na kasi namin yung GD.
    But on my Patrol, the door ajar warning also doesn't work with the key cylinder in the OFF position. The dome lamps still turn on when set in the DOOR position but the dash lamp doesn't illuminate. And that is the OEM set up even before any work was done on my vehicle.
    Not also sure about the rear doors. But that is how our former Volvo also worked (it had a more expensive Autopage system). The system cannot detect the tailgate as it uses a different wiring harness from the other doors.
    Better to have it checked with Jemson na lang to be sure.
    Better also to ask him if he put in the ignition kill. One sure way to test it is to arm the alarm, open doors manually (siren will sound) then try to start the vehicle. If car doesn't start, you have ignition kill.
    sir,
    ganun nga ata yung sa gd. sir yung ignition kill ba yung nagpalagay kayo ng additional switch na pang bypass if ever nagkaproblem?
    btw, naexperience nyo po ba sa alarm nyo yung ganito, kasi minsan pag arm ko, di pa ko nakakalayo tapos biglang tutunog ng isa parang warning, tapos biglang mag aalarm na. minsan bigla lang nagiging ganito yung alarm.
    Jul 2010
    #288
    Force Alarms users,
    anybody na nasiraan na ng remote? I had mine installed August 1 lang by Jemson so fairly new pa. Last week nung umaga when i arrived sa office okay pa ung remote at na-arm ko pa ung alarm, pagbalik ko sa hapon ayaw na ung remote mag disarm. Hindi naman nabagsak or something yung remote. I'm using the spare already. Covered naman to ng warranty dba? Sabi Jemson 1 year warranty ung unit e. The faulty remote's indicator still lights whenever you press arm or disarm, pero it doesn't trigger the alarm system.
    Sep 2005
    #289
    dala mo ba parati yung spare?? baka grounded lang yan.. send nang send nang signal yung isang remote.. kaya ayaw gumana nung isa..
    Jul 2010
    #290
    bro nung nasiraan ako ng remote hindi ko dala yung spare asa bahay. so i had to do the manual override disarm.
    Jun 2006
    #291
    Quote Originally Posted by beefydog View Post
    sir,
    Recently experiencing this. Pag arm ng Alarm mag-si-signal siya ng isang chirp, then after 4-5 seconds it will sound the alarm once.
    Jul 2010
    #292
    binalik ko defective remote ko to Jemson, he asked me to leave the remote with him for 5days so he can have it checked thoroughly. After 5 days i came back and he reprogrammed the remote and it worked again. Conclusion is, the remote lost frequency with the receiver. Cheers for the great service of Jemson.
    Oct 2009
    #293
    mga sirs baka meron na nakapag reprogram ng remote sa inyo? ask ko sana kung how much? or baka meron din kayo marerecommend na shops doing this? TIA
    #294
    Quote Originally Posted by marv_chua View Post
    Sino po merong pdf ng manual ng force alarm? pede po paemail sa michua*unilab.com.ph since nun nakalimutan ibigay sakin ni jimson un manual nun ininstall nya un alarm.
    Nangyayari po ba sa inyo na after nyo off car nyo then hugot nyo un key, the dome light will open diba. after the dome light close, mag blink un led ng many times then mag activate na un alarm pero indi nya ilock un mga doors. dati hindi naman automatic nag activate yun. hassle kc minsan may kunin lng ako sa trunk, disarm ko cya then after ko makuha gamit, then close ko un trunk biglang mag alarm un pala nag automatic arm na sya.
    Na-solve na ba ito? Hanggang ngayon kasi ganito parin yung alarm ko.
    #295
    mahusay nga itong si jemson, he installed this alarm sa 2000 revo ni erpats last week.
    nag-add din ako ng diode para yung signal light ang umilaw, i really hate those alarms (e.g. cheap cobra) na flash ng flash park lights pag ni-open mo pinto hehe..
    medyo sensitive yung default shock sensor, pa-adjust nyo to least sensitive settings,
    babalik din ako kay jemson, kelangan kasi naka-on dome light bago i-arm para 1-chirp during arming, pag naka-off dome-light ko, 3-chirps at na-bypass yung door-ajar sensor.
    Jan 2012
    #296
    newbie here. pwede po mahingi yung contact number ni sir jameson? balak
    ko rin kasi magpakabit ng alarm eh.. TIA
    #297
    Nasa first po nh jemson thread ang contact at address niya
    Oct 2009
    #298
    meron po ba nabibili na repalcement sa remote ng alarm? saan po kaya ang shops na nag bebenta neto kung meron man?...TIA
    Jul 2011
    #299
    In my observation, this FORCE alarm is truly cheap and bang for the buck, but not that really 'dependable' during the first days/months of use.
    As per the posts dictates, they usually encounter one or two problems and had to return to Jemson for a fix so it will act normally again.
    Anybody here never encountered a single problem since installation? Im getting less motivated to have this alarm coz we can't have the luxury of going back to Jemson because my Hiace is for my van-for-rent business and it is always out in far-flung provinces.
    Peace!
    #300
    Other than the drawings on the buttons getting erased, my unit has been trouble free. Its installed in a 2001 Patrol.
    But now i prefer buying the viking system from sulit.com. 1k lang kasi. But i still have jemson do the install
Budget Special: FORCE Vehicle Security System
