Results 1 to 20 of 337
    Jan 2009
    nagpakabit ako ng force alarm kahapon and oks nga sya. thanks to doc otep. highly recommended si jemson.
    may ilang questions lang ako regarding sa alarm.
    gd yung auto namin, ang napansin ko, pag nakapatay makina tapos nagbukas ka ng pinto, hindi na lumalabas yung door ajar warning. pag nakaon lang yung makina tsaka lumalabas, ganito po ba yung sa inyo?
    tapos pag nakabukas yung likod, di nya kinoconsider as open na door, kasi kahit bukas sya nagaauto lock pag inistart makina o yung passive arming. ganito po ba yung sa inyo?
    parang feel ko kasi parang weird lang yung response nya.
    thanks.
    it should not be that way. door ajar warning should work even without a key. rear door should also be connected to door ajar warning.
    Jan 2009
    Quote Originally Posted by Ginnova View Post
    sabi na eh. tinext ko na din si jemson. balik ko na lang pag free ako. thanks.
    I'm not sure about the GD (other GD owners can chime in). Nabenta na kasi namin yung GD.
    But on my Patrol, the door ajar warning also doesn't work with the key cylinder in the OFF position. The dome lamps still turn on when set in the DOOR position but the dash lamp doesn't illuminate. And that is the OEM set up even before any work was done on my vehicle.
    Not also sure about the rear doors. But that is how our former Volvo also worked (it had a more expensive Autopage system). The system cannot detect the tailgate as it uses a different wiring harness from the other doors.
    Better to have it checked with Jemson na lang to be sure.
    Better also to ask him if he put in the ignition kill. One sure way to test it is to arm the alarm, open doors manually (siren will sound) then try to start the vehicle. If car doesn't start, you have ignition kill.
    Dec 2009
    Bakit po hindi na naglolock yung driver side lock ko pag in-arm and dis-arm ano kaya problema? FORCE ALARM DIN AKO FROM BOSS JIMSON
    Pano pala itemporarily disable yung alarm? Pag sa carwash kasi pagbukas ng pinto nag aalarm e.
    Jul 2010
    press arm, then within 3 seconds press again arm. This will arm the alarm but delete the shock sensor. Alarm will trigger if doors are opened.
    Just got the Force alarm today kaya fresh pa yung tutorial ni Jemson on the features Installed the alarm in less than an hour. Cost are as follows: 1600php Force alarm, 300php labor, 150php diode to use signal lamps instead of park lights. Very clean installation, great workmanship. Recommended installer. More power to our Force Alarm!
    Jan 2009
    sir,
    ganun nga ata yung sa gd. sir yung ignition kill ba yung nagpalagay kayo ng additional switch na pang bypass if ever nagkaproblem?
    btw, naexperience nyo po ba sa alarm nyo yung ganito, kasi minsan pag arm ko, di pa ko nakakalayo tapos biglang tutunog ng isa parang warning, tapos biglang mag aalarm na. minsan bigla lang nagiging ganito yung alarm.
    Jul 2010
    Force Alarms users,
    anybody na nasiraan na ng remote? I had mine installed August 1 lang by Jemson so fairly new pa. Last week nung umaga when i arrived sa office okay pa ung remote at na-arm ko pa ung alarm, pagbalik ko sa hapon ayaw na ung remote mag disarm. Hindi naman nabagsak or something yung remote. I'm using the spare already. Covered naman to ng warranty dba? Sabi Jemson 1 year warranty ung unit e. The faulty remote's indicator still lights whenever you press arm or disarm, pero it doesn't trigger the alarm system.
    Sep 2005
    dala mo ba parati yung spare?? baka grounded lang yan.. send nang send nang signal yung isang remote.. kaya ayaw gumana nung isa..
    Jun 2006
    Quote Originally Posted by beefydog View Post
    sir,
    Recently experiencing this. Pag arm ng Alarm mag-si-signal siya ng isang chirp, then after 4-5 seconds it will sound the alarm once.
    Jul 2010
    binalik ko defective remote ko to Jemson, he asked me to leave the remote with him for 5days so he can have it checked thoroughly. After 5 days i came back and he reprogrammed the remote and it worked again. Conclusion is, the remote lost frequency with the receiver. Cheers for the great service of Jemson.
Budget Special: FORCE Vehicle Security System
