Results 1 to 20 of 337
    The Code Alarm on the Jimny died. I know its serviced by Winterpine but it was a Saturday night and I don't want to think about it come Monday (I'm quite tied up at work).
    So I just had Jameson remove the system and put in a Force system. So far so good, still fine tuning the sensitivity.
    Reused the siren and LED from the CODE alarm. Also had the starter kill module from the Force installed.
    doc otep, question lang po, paano po itune yung sensitivity nung alarm?
    May separate shock sensor with adjuster yung Force po
    ah so i have to purchase it separately pa? kasi i had kuya jameson install the force alarm on my vitara last week, kala ko kasama na don yong shock sensor hehe
    Meron iyan. just ask him where he placed it. The unit will not work without it. It's just a small black box with a knob on the body.
    Oct 2009
    i bought the force alarm last saturday from sir jameson. maganda yung alarm based on my needs.
    ito napansin ko sa alarm:
    • medyo nahihinaan ako sa siren, pero pwede naman palitan yun ng ibang siren.
    • di ko ma-configure yung password change setup. sinunod ko naman yung nasa manual na "9x gagawin", pero mukhang ayaw. meron na po ba nakapag-change ng password?
    • mukhang nadi-disable yung alarm module pag umaandar na yung kotse, kasi tinry ko i-lock yung kotse while the engine is running, pero ayaw. yung dati kong alarm, pwede yung ganun. useful kasi ito minsan pag madalian lang yung pagbaba (i.e. daan sa cr ng gasoline station) para di na papatayin yung engine. di ko lang sure kung out of scope ito nung force alarm or pwede magawan ng paraaan
    *marvinix: meron po syang shock sensor, merong knob na maliit yun. afaik, dapat kinabit yun sa isang matigas na part ng kotse mo (i.e. chassis). most likely nasa area yun sa ilalim ng driver side dashboard
    *otep: i like the way you recommend the force alarm, and the electrician you suggested. ok na ok po si sir jameson. many thanks for the recommendation
    Dec 2007
    Installed the Force Alarm kanina lang. The whole thing lasted from I think 10am hanggang 5:30 Not in the negative way, pasaway lang ang auto ko.
    The alarm costed me 1700 pesos. Not bad. Masaya na ako. with 300 petot labor. Dinalahan ko ng breakfast si Jameson kasi baka di pa kumakain umagang umaga dinistorbo ko. Overall cost is 6000 kanina. 4000 lang dala ko pera babalik ko bukas yung 2000. Madaling kausap si Jameson highly recommended.
    I will post yung mga pinagawa ko sa auto as reference to our fellow tsikoteers.
    Force Alarm: 1700 pesos
    Installation: 300 pesos
    Diode para sa signal light yung light ng alarm: 150 pesos
    Stebel Magnum horn: 650 pesos
    Installation: 100 pesos
    My central lock is not working and so is my power mirrors. Nag submarine kasi ang kotse ko noong bagyong Ondoy, mga kalahating tao pa above the roof ang tubig. At nababad dun for 6 hours. Na asikaso ko lang ang auto after 3 days, dun ko lang na disconnect ang battery.
    Repair of the motor locks sa pinto: 300 each door. 5 door ang tsikot ko, sabi ko 1,200 na lang okay naman. Na stock up kasi ang motor ng power lock ko.
    Module for the power lock, 650. Yung utak lang ang kinuha, babalikan ko ang galamay bukas.
    Repair of the stock up motor sa power mirror: 800 for the pair.
    Repair of the naglolokong fog light, nilagyan ng relay and wiring, 500.
    Nabitin pera ko eh ibabalik ko na lang bukas.
    Overall, happy ako. Tigbak ang kotse ko eh, estimate sa casa is 50k conservative, wala pang parts na papalitan yung comp box lang. 10k pa lang nagagastos ko gumagana na lahat except the EPS. Happy ako nag ka power locks ako, nag ka sensor alarm pa. Happy rin ako gumagana na power mirrors ko at ang fog lights di na nagloloko.
Budget Special: FORCE Vehicle Security System
