Results 1 to 20 of 337
    Dec 2007
    Mga bro kamusta ang feedback niyo sa FORCE alarm system?
    Naghahanap kasi ako ng aftermarket alarm for my car.
    The Code Alarm on the Jimny died. I know its serviced by Winterpine but it was a Saturday night and I don't want to think about it come Monday (I'm quite tied up at work).
    So I just had Jameson remove the system and put in a Force system. So far so good, still fine tuning the sensitivity.
    Reused the siren and LED from the CODE alarm. Also had the starter kill module from the Force installed.
    doc otep, question lang po, paano po itune yung sensitivity nung alarm?
    May separate shock sensor with adjuster yung Force po
    ah so i have to purchase it separately pa? kasi i had kuya jameson install the force alarm on my vitara last week, kala ko kasama na don yong shock sensor hehe
    Meron iyan. just ask him where he placed it. The unit will not work without it. It's just a small black box with a knob on the body.
    Oct 2009
    i bought the force alarm last saturday from sir jameson. maganda yung alarm based on my needs.
    ito napansin ko sa alarm:
    • medyo nahihinaan ako sa siren, pero pwede naman palitan yun ng ibang siren.
    • di ko ma-configure yung password change setup. sinunod ko naman yung nasa manual na "9x gagawin", pero mukhang ayaw. meron na po ba nakapag-change ng password?
    • mukhang nadi-disable yung alarm module pag umaandar na yung kotse, kasi tinry ko i-lock yung kotse while the engine is running, pero ayaw. yung dati kong alarm, pwede yung ganun. useful kasi ito minsan pag madalian lang yung pagbaba (i.e. daan sa cr ng gasoline station) para di na papatayin yung engine. di ko lang sure kung out of scope ito nung force alarm or pwede magawan ng paraaan
    *marvinix: meron po syang shock sensor, merong knob na maliit yun. afaik, dapat kinabit yun sa isang matigas na part ng kotse mo (i.e. chassis). most likely nasa area yun sa ilalim ng driver side dashboard
    *otep: i like the way you recommend the force alarm, and the electrician you suggested. ok na ok po si sir jameson. many thanks for the recommendation
Budget Special: FORCE Vehicle Security System
