Results 3,321 to 3,330 of 3510
- Oct 2019
- 14
January 9th, 2020 04:20 PM #3321Thanks sir yub! Yan din ang pitch ni seller sakin, free installation plus yung quick capture button ata. Ill compare the night clips of ddpai with viofo. If i can tolerate the decrease in quality, ill opt for the ddpai. May gusto din kasi ako gawin dun sa front cam ng ddpai. My car unit has a black plastic protion na naghohold sa rear view mirror, im planning to stick it there instead sa windshield para magamit din as interior cam. I dont think you can do that with the a129?
- Sep 2016
- 2,348
January 9th, 2020 05:19 PM #3322
- Oct 2019
- 14
January 9th, 2020 05:53 PM #3323Had a convo with the installer of ddpai, it would need two usb ports for the front and rear setup pala. Looks like ill back read muna all the entries here.
I watch some night vid clips on yi, ddpai and viofo. Seems like yi and ddpai has the same quality (imo). Viofos night vid clarity is crazy good
- Sep 2016
- 2,348
January 9th, 2020 07:05 PM #3324Yes sir, it will need two USB ports, tig-isa sila.
What's your car sir? Mobilio pre-facelift kasi sa amin at isa lang ang cig port nya. Bumili ako ng Remax Cr-3XP na charger. 2 cig ports with 3 USB ports. I use the 2 ports. Yung dalawang dashcam sa 2.1A nakakabit. Yung other 2 ports na 1.0A, for charging gadgets.
- Oct 2019
- 14
January 9th, 2020 10:00 PM #3325Thanks sir yub sa smart car charger recommendation! This will solve my port and wiring issue with the ddpai f&r dash cam setup.
I have a Mazda3 2020. The 12V cig charger is under the center console arm rest so medyo hassle ang location nya.
Now im going to have to decide what should I choose:
1. Viofo A129 Duo with only 1 port required (assuming I can plug this to my USB port dash) but I have to install it by myself. Or go
2. DDPai mini3&1 combo but I need to buy the smart car charger
I may need to do a lot of backreading tonight
January 9th, 2020 11:22 PM #3326
Get the A129. It'll work with your USB port for a cleaner install. Installation is easy - just bring it to any car electronics shop and pay for labor.
If you go for the DDpai you can still make it work with the USB port - just get one of these (82 pesos from Lazada):
Dash cams are low-power devices and the 2A port should power 2 devices just fine.
- Oct 2019
- 14
January 10th, 2020 04:34 AM #3327
- Oct 2019
- 14
January 17th, 2020 02:39 PM #3328Just an update: bought the DDPai combo for front and rear (Mini3 & Mini1).
Pros:
Aesthetically pleasing
Emergency clicker is already included
Cons:
Night usage. Pag di well lit yung area, halos wala na akong makita sa rear and konting visibility lang sa front.
So far, no regerets pa rin naman. Curious to know the quality sa night recording ng viofo a129 duo on our not so well lit streets.
And to all na nagsabi na madali lang mag install, madali nga lang 😂. Medyo inulit ko kasi yung installation dahil sobrang OC ko sa pag center nung cameras.
January 17th, 2020 07:04 PM #3329
February 29th, 2020 09:42 AM #3330
Are they on track to surpass last year's sales?
Car Sales Data (2025)
