Results 1 to 10 of 3510
    Oct 2019
    Naka-DDPAI Mini2P ako sa harap sir at DDPAI Mini sa likod. Both capacitor type na sila. Libre install ni seller. Okay pa rin naman sya so far. Malinaw sa daytime, sa night time medyo madilim pag di well-lighted yung area na dinadaanan mo. Pero enough naman yung quality kung kailangan mo ng evidence just in case mafigure ka sa accident/bangga.
    Planning on replacing it with Viofo A129 Duo din in case bumigay na sila.
    Thanks sir yub! Yan din ang pitch ni seller sakin, free installation plus yung quick capture button ata. Ill compare the night clips of ddpai with viofo. If i can tolerate the decrease in quality, ill opt for the ddpai. May gusto din kasi ako gawin dun sa front cam ng ddpai. My car unit has a black plastic protion na naghohold sa rear view mirror, im planning to stick it there instead sa windshield para magamit din as interior cam. I dont think you can do that with the a129?
    Sep 2016
    Quote Originally Posted by charlesnico1 View Post
    I don't have night videos saved sakin eh, wala tuloy ako mashare. Yes, may bluetooth remote syang kasama so pwede ka magpicture anytime na may gusto ko picturan.
    Let's wait for the A129 owners for your inquiry.
    Oct 2019
    Had a convo with the installer of ddpai, it would need two usb ports for the front and rear setup pala. Looks like ill back read muna all the entries here.
    I watch some night vid clips on yi, ddpai and viofo. Seems like yi and ddpai has the same quality (imo). Viofos night vid clarity is crazy good
    Sep 2016
    Yes sir, it will need two USB ports, tig-isa sila.
    What's your car sir? Mobilio pre-facelift kasi sa amin at isa lang ang cig port nya. Bumili ako ng Remax Cr-3XP na charger. 2 cig ports with 3 USB ports. I use the 2 ports. Yung dalawang dashcam sa 2.1A nakakabit. Yung other 2 ports na 1.0A, for charging gadgets.
    Oct 2019
    Thanks sir yub sa smart car charger recommendation! This will solve my port and wiring issue with the ddpai f&r dash cam setup.
    I have a Mazda3 2020. The 12V cig charger is under the center console arm rest so medyo hassle ang location nya.
    Now im going to have to decide what should I choose:
    1. Viofo A129 Duo with only 1 port required (assuming I can plug this to my USB port dash) but I have to install it by myself. Or go
    2. DDPai mini3&1 combo but I need to buy the smart car charger
    I may need to do a lot of backreading tonight
    Get the A129. It'll work with your USB port for a cleaner install. Installation is easy - just bring it to any car electronics shop and pay for labor.
    If you go for the DDpai you can still make it work with the USB port - just get one of these (82 pesos from Lazada):
    Dash cams are low-power devices and the 2A port should power 2 devices just fine.
    Oct 2019
    thanks for the reco sir jut! will think about it thoroughly
    bro malaki pa difference sa quality ng night time driving sa ddpai mini2p vs mini?
    may nakapag test na ba ng ddpai minione vs mini2p sa nighttime driving?
    thanks!
Blackbox DVR/Dashcam
