Results 1 to 20 of 3510
    Jun 2009
    Heat doesn't really penetrate the car's headliner (otherwise, it'd be very hot inside your car the moment you expose it to the sun). Hindi siya parang yero na sobrang init.
    Also, the cable still has its housing, it's not exposed. The housing won't melt unless you subject it to really really hot temps like a soldering gun. From the inside out, it also won't heat up unless the + and - wires are grounded, but since I didn't touch any of that, it's safe.
    Worst case scenario is an oversupply of voltage from the AC power, but that's why I had a fuse installed for additional safety.
    Thanks for the info.
    Nagdadalawang isip kasi ako, baka kasi sobrang uminit ang wire dahil balak ko rin ipadaan , diy, ang wire dun sa gap ng headliner at sa windshield..
    Ang isa pang concern ko is mas malaki ang size nitong nabili ko na 3m wire (color white) compared sa original (black) ng sj ko. . .
    Quote Originally Posted by KERSMcRae View Post
    generally mas makapal ang wire bro mas safe
    Jan 2012
    pero mahihirapan sya isiksik sa ceiling at A pillar yang ganyan kakapal na cable.
    kaya yan. ano nga ba ang auto ni KERSMcRae?
    Jun 2009
    Quote Originally Posted by benchman View Post
    Ertiga ..
    Plano ko kasi ilagay dun sa gap between ng headliner at windshield..
    try mo kung kaya i-tucked under the headliner. usually inaangat lang ang headliners(though with toyota).
Blackbox DVR/Dashcam
