Results 551 to 560 of 3510
April 24th, 2015 04:08 PM #551
For those w/ SJ400, you can use (1) a suction mount (to be bought separately) to install in to the WINDSHIELD; clamp to install it underneath the REARVIEW MIRROR; or, the flat adhesive to install it on the DASHBOARD.
For me, it looks nicer if you will install it on the DASHBOARD using the flat adhesive.
April 24th, 2015 04:30 PM #553
uhm, wag naman sana. hahaha!
because i installed mine using the adhesive. then with the right combination of clips, you can easily move it to front, left and right =)
also, mas madali sya tanggalin kapag nagpapark ako sa nakabilad sa araw..
although, i have a suction mount. di ko na ginamit dahil mas comfortable ako na nasa dashboard sya.
how about cable management? kasi may portable GPS din ako. bukas, maayos nga lahat hehehe
April 24th, 2015 04:32 PM #554
about VK70, paano kaya malaman kung orig? Mine is just free from the casa na Vkool daw. I specified I want the lightest tint on my front windshield then medium on the rest. From the outside looking through the windshield, pag maaraw di mo makita ang occupants, pero pag gabi na, parang walang tint. Is that normal?
about the clamping, I suppose the tint, being a soft material, would lose its adhesion over time when there's something pulling it (is the dashcam that heavy?).
I am thinking, I'd use the rearview mirror post for this purpose (thinking of Xiaomi Yi but waiting for a dual channel). Di naman siguro basta basta matatanggal yun?
April 24th, 2015 05:03 PM #555
Bro, if it's just free from the casa, most definitely that isn't VK70. If you avail for light tint, that's OEM 35, then medium is OEM 20, and dark is OEM 05.
The SJ4000 and its suction cup isn't very heavy, but the suction force is pretty strong, and it might be that the repeated removal and installation weakened the adhesion of the tint to the glass.
My problem with the Xiaomi Yi is that it doesn't have a Car Mode so it doesn't open automatically, and it doesn't come in black so it's too ubiquitous.
- Mar 2009
- 823
April 24th, 2015 06:04 PM #556
April 25th, 2015 06:41 AM #558
- Mar 2013
- 6,160
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
