Yup. It's an active GPS receiver. It needs 5V power from the DVR and it sends back GPS coordinates using serial communications (ie. NMEA 0183 protocol). The memory backup battery is a dead giveaway. The memory serves to store ephemeris data and whatnot.
No I haven't tinkered with it. Like you, I also temporarily disconnected the GPS module.Oj88,
Nagawa mo na ng paraan yung GPS battery issue? Yung akin kasi di ko na lang kinabit. I'm thinking of installing a switch to cut off the power when not in use or better yet a 5v normally open relay para automatic.
I've thought of using a relay as well, one which can be triggered by the DVR's backlight circuitry or the power LED. The thing is, I'm not sure if the 3.7V LiIon/LiPoly battery will be enough to energize the 5V relay. In that regard, I think that a solid state approach is preferred (smaller package and lower power draw). I just haven't found the time to design the circuit yet.
But do tell if you make any developments.
