Results 11 to 16 of 16
October 11th, 2017 12:57 AM #11
I didn't just decide to replace it blindly. I'm 45 and all my life has been dedicated to breaking and rebuilding stuff.
Of course I did due diligence and confirmed that the part was actually defective before ordering a replacement. And in my case, it wasn't the electric motor, rather, a small gear that has cracked and started slipping from its shaft is what's causing me a lot of greef.
I figured that I just get it over with and looked for the whole assembly. I eventually found one from a wrecked 2011 Civic (USDM) posted on eBay for $48. Part numbers were almost identical but more importantly, they looked exactly the same.
I replaced the whole assembly myself.
Spending just a little under 2.5k* for the whole latch assembly (including S&H), it's a bargain. I got to learn about the innards of the car door pa.
*Note: My earlier estimate was based on the current Forex. The Forex rate at the time I bought it (March, 2014) was just around P45 to the US Dollar.Last edited by oj88; October 11th, 2017 at 01:00 AM.
- 52,731
October 11th, 2017 06:18 AM #13
- 52,731
October 11th, 2017 07:09 AM #14
- Mar 2016
- 51
October 11th, 2017 09:35 AM #15Boss, buksan mo may natanggal lang po yan sa loob, ganyan din sa akin dati yong door ko sa right side sa hulihan ayaw din sumabay kapag lock at unlock meron lang akong kinabit kc natanggal diko lang alam ano tawag don naka-kalawit sya yun lang napansin ko na nakatanggal sya yung tumutulak ng unlock at lock. buksan mo tapos pindot pindutin mo remote makikita yun gumagalaw... sana makatulong ako...
- Sep 2018
- 5
September 7th, 2018 11:49 PM #16
high idle RPM at engine start
