Originally posted by niky
But the fuel pump killswitch is sneakier... they would be about 50 meters away before the car stops... enough time for you to run. :D
actually the fuel pump kill switch will stall the engine the moment when they floor the gas pedal... basically the engine will run on what gas is left in the fuel line (not much). You can try it by pulling out the fuse for the fuel pump from your car's fuse box (location may vary depending on the car make and model).
But even then, you'll be outside the car so you can run away... you can always go back for your car later, its not going anywhere with no gas going to the engine.
