Results 1 to 1 of 1
March 16th, 2015 07:54 PM #1
Hello,
Curious if may mare-recommend kayo na car electrician that has already done / installed a PKE alarm to another car? Dumaan kasi ako kila Jemson kanina to see if they can install one pero tinanggihan eh. Masyado raw maraming wiring na gagalawin on top nung additional pang requests kung sakali. May mga additional features kasi on top pa ng basic alarm na kayang gawin ng alarm module, and I think dun napaangal sila Jemson... namely:
1) Basic car alarm installation (lock / unlock / siren / etc.)
2) Trunk release relay
3) Trunk actuator (for the release relay to work)
4) Central lock replacement (one that came stock with the car is failing already)
5) Engine Start / Stop button
6) Key cutting (needs to be done as the start / stop button will be installed on top of the key hole - "cut" key needs to be left within the ignition switch and set to ACC so as to disable the steering wheel lock)
Unfortunate lang talaga na umalis na yung suki kong electrician sa Evangelista na willing sa mga ganito basta may manual, so kung may mare-recommend kayo pa-post lang dito. TIA!
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
