Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 64
    #51
    Most tire inflators can only be used for up to 5 minutes tops ... otherwise they overheat ... read the instructions ...
    umaabot ba ng 5 minutes from, flat to 30psi?
    #52
    puede pang lumampas.
    depending on the size of the tire.
    from alto's to pajero's...
    also,
    some older ones are less efficient than the newer ones.
    #53
    195/65/15?
    #54
    195/65/15?
    puede siguro. basta hindi laspag ang compressor ng inflator.
    Sep 2016
    #55
    My spare tire, 185/65/R15, I think it took 1-2 minutes to reach 32 psi from 8 psi.
    #56
    Meron bang inflator na dual pwede sa 12v and saksak sa 220v?
    #57
    oh not bad pala bro. pwede naman siguro pahinga after 2 minutes, tapos bomba uli
    #58
    that's what i did, with my former inflator. it took some time, to get the tire inflated to the correct psi.
    in disgust, i afterward went out and bought a new one. it worked very well, at first. but after two years, the orange coiled tubing was disintegrating.
    Sep 2016
    #59
    Yes sir. Ganun nga ginawa ko. Pero yung 4 tires ko, since mga 2-3 psi lang binababa every week, sinusunod-sunod ko na ng bomba.
    Do you leave the inflator inside your car, doc? Yung akin kasi nasa likod lang. Di kaya lumutong din agad yung tubing nya dahil sa init sa loob ng sasakyan?
    #60
    fast forward two years.
    well,
    this elevo that i praised to the high heavens a while back...
    the orange tubing broke at the proximal end! the entire tubing is matigas na at crumble-able with one's hands.
    the rest of the pump still functions well, however.
    where can i have that tube replaced?
    i have asked around, and they didn't know where.
    i think we have the same inflator doc. sira na din yung tube kaya I have the same problem
Affordable  and Portable Tire Inflator (12V cigarette lighter socket)
