Results 1 to 2 of 2
    Oct 2013
    [edit: can't find delete-post button. moved to proper sub-forum. Pls delete post. Thanks]
    Sep 2004
    Math muna unahin mo, calculate the load that your present and future accessories will need. Once you have this you'll be able to determine which wire gauge to use, also what fuse rating and finally relays that will handle the load.
    All connections ng accessories mo straight sa batt thru a fuse, then activated lang sila ng relays. The relays then can be tapped to:
    For #1 sa on key position, the wries are just under the steering column. Use a tester to find a wire that powers on when the key is turned to the on position.
    For #2 sa door sensors, you should be able to find its prime wire by the dead pedal plastic cluster. Do not use the one found in the gauge cluster.
    3. If you did the math first yes you can do this, pili ka nalang which relay to connect it to, the one that activates sa key on position, or the one that activates thru the door.
Accessory wire: where to tap/splice?
