Just follow the instructions below -
1. Install MapSource on your computer. Note that the disk is DVD and not a CD.
2. Download the 5.00 Beta version of the maps from the site - http://www.freewebs.com/phroadguide/index.htm
3. Run the exe progam that you downloaded. This will install the maps in your MapSource.
4. Open MapSource. In the drop down list of the the maps, select Phillipines Routable v5.00 Beta.
5. Using the Map select tool, highlight the map segments (or all of them) that you want to load to your GPS unit.
6. Connect your GPS unit to your computer with the USB cable.
7. Click the Send to Device button in MapSource.
8. When the Send to Device dialog box comes up, select your GPS unit or your SD card as the destination.
9. Be sure the Maps check box is checked.
10. Click Send.
11. Clik Ok when MapSource is done sending the maps.
12. Disconnect your GPS unit from your computer.
13. Once the unit boots up, check to be sure the maps are selected. Wrench/Settings > Map > Map Info
14. Pan and browse the map to the area where the maps are located. You should see the outline boxes of the map segments.
15. Zoom in.
![Google Play GPS Navigation System [merged threads]](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)
