Quote Originally Posted by ferrarifan View Post
So what Philippine map are you loading in your products, roadguide.ph or OSM?
i gather the data from osm and my actual tracks (as much as possible i do the tracing/plotting using my gpsr) i use also a particular software to do the mapping
i tried once roadguide.ph's 17mb version (the free version) it has lot of things to improve, i tried also to contribute but then i think they are too busy to entertain my uploaded tracks so i look for an alternative way and studied it, tested it actual turn by turn and testing in all garmin models
by the way, for info, roadguide.ph map does not work on nuvi 1300T and 1690T, you can install it but once you select the "View Map" there is no visible roads on it
