my car is a 2002 chevrolet optra. earlier today i noticed pag baba ko ng kotse na yung brake lights hindi namamatay even though i had taken the keys out already. i double checked if my light switch was on "off", and sure enough, it was. i just jiggled the brake pedal a bit and eventually namatay na yung ilaw. akala ko ok na, but when i got home tonight, ganun ulit nangyari. i tried the pedal trick again but it didnt work. also tried starting and stopping the engine to no avail. finally, i decided to take out the brake light fuse to see if that could fix it. syempre namatay yung ilaw but when i put the fuse back in the lights just turned back on.![]()
does anyone have an idea what the problem could be? brake lights lang talaga yung problema. the regular rear lights are fine, and so are all the other bulbs. i was thinking baka may naipit lang na wire or something because on the first incident eh gumana yung pag jiggle ko sa brake pedal.
i just removed the fuse for now para di ma-diskarga yung battery pero syempre ayaw ko naman iwanan lang ng ganun since driving without brake lights is quite dangerous.
any helpful ideas will be appreciated, i was hoping sana for a DIY solution para walang hassle sa pagpunta ng shop at and of course tipid na rin. thanks guys![]()
