hey kakabili ko lang ng AWB kanina .. very satisfied user here ..
ill post pics bukas![]()
i have altis 2004, do i need to replace my grounding if i put higher wattage bulbs? would it burn my wires? whats the max wattage capacity of altis's stock wirings? hope for your advice... i currently have stock bulbs, and planning to buy a high wattage bulb...hb4 for the low and hb3 for high beams...fog lights are h3...all stock wirings...dont have money for an hid kit...and i think its unpractical to make silaw of your opposing cars...![]()
are your altis lights dimm? have you compared your light throw to other vehicles? altis has one of the brightest throw I see on the roads today. baka need replacement of bulbs lang yan and some headlight cleaning. and go for same wattage but more light throw like silverstar, nightbreaker or xtreme. para no need to upgrade any parts.
Osram Silver Star is stock 60/55 watts with 50% more light than stock. Osram Night breaker is stock 55/60 watts with 90% more light + 10% whiter than stock.
Philips Vision Plus is stock 55/60 watts with 50% more light than stock. Philips Xtreme is stock 55/60 watts with 80% more light thank stock
some few info here: http://tsikot.yehey.com/forums/showt...t=40777&page=5
you can also google them.
sir squilicot...ganda po pala ng naka hid...dame nga po ako nakikita na naka hid and it seems na maporma po talaga...and it crosses my mind na if il still go for all weather or hid kit...which do you prefer for daily use and life span? thanks po ng marame
you can buy them at 550 per bulb here (click) or check the "nightbreaker" thread.
nakabili na ako ng narva all weather h4 100/90W at ceramic sockets.. may mga katanungan ako...
1. bakit naka steady naka ilaw yung high beam indication lamp kahit dim or bright(yung kulay blue).
2. bakit mas maliwanag yung dim sa bright? kapagka kasi naka high beam parang dumidilim lalo yung ilaw.. bakit kaya ganun?
3. bakit ganun pag high beam parang wala. hindi ba sya kagaya ng stock halogen na pag high beam e kita malayo at bubong ng bus o trak?
ALAM KO NA!!!!!... bobo ng nagkabit ng ceramic socket.. bali baliktad yung. sa pula, sa puti, sa blue, sa pula.. ano b un.. ok na ngyn.. may hi and low beam na at di na naka steady yung high beam indication lamp kahit naka low beam.. bobo talaga ng nagkabit ng ceramic socket.. bobo...
tanong ko lang60/55W yung stock namin dati.. ngyng 100/90 W na ako allweathers, di ba mangingitim yung headlight casing namin???... o masusunog yung may chrome???..... sabi kc sa danielstern yung 100/90W na ilaw can damage plastic lamps.. ano kaya?? ipa trade-in ko na tong 100/90W ko ng 60/55W ulit na all weather?? di kaya medyo dumilim na ito kagaya ng stock??
Hindi naman nakaka itim ng headlight yung 100/90 na all weather eh. Since 2005 naka 100/90 na ako sa Trooper. Hindi parin nangingitim. Medyo madumi lang talaga yung loob kasi 2003 pa yung headlight at di ko pa napapa linis.
Hi guys, advisable ba to use all-weather bulbs if you have a medium tinted windshield? thanks
