Results 1 to 10 of 16
- 37
November 13th, 2002 09:50 AM #1ayaw sumindi ng reverse gear light ko. may nagsabi sa akin na baka raw siira na switch. san ba located yun? pwede ba DIY yun? oldschool corona auto ko e. any idea how much yun? thanks peeps!
November 13th, 2002 10:09 AM #2
have you cheked the fuse???
i think my fuse yan for the reverse light.
hope this helps.
- 63
November 13th, 2002 10:30 AM #3Dude,
I have the same problem as yours... check the fuse... check the bulb... check the sensor which located near the tranny... my problem was the sensor... i haven't had it checked yet.
- 130
November 13th, 2002 10:43 AM #4same here, tagal ko na problema yan pero di ko pinapansin. para kasing its not as important as signal lights kaya ok lang.
kaya lang the other night, while is was backing up, di ko napansin that there another car parked behind me dahil sobrang dilim.. ayun sapul! :?
November 13th, 2002 11:29 AM #5
You can check the bulb, fuse and electricals among some but in the case of our AE101 and AE92 Corolla before, it was the switch. I dont know where it is though as i just had a shop work on it.
- 37
November 13th, 2002 12:20 PM #6ok fuse at bulbs eh, kaya malamang switch talaga. di ko lang alam kung nasan yun. di ko kasi pwede ignore dahil mahirap magreverse sa gabi, naka tint pa naman ako ng s. black. thanks sa mga sagot:D
November 13th, 2002 01:54 PM #7
pa taas mo sa gas station baka nahugot lang sa switch yung wire. hindi naman sirain yung switch nyan pwera na lang kung nabasag...
kung papalitan mo naman ganun din patataas m din sa gasoline satation mura lang naman pataas p20 lang
- Nov 2002
- 25
November 14th, 2002 04:02 PM #8ganyan din yung corona gl ko, had it checked by an auto electrician sira na yung reverse sensor switch. mga 1k ang brand new sa banawe but you can also ask those surplus shops mas makakamura ka. got mine for 200 kasama na installation mga 3 months na siya ok pa naman. d ko lang alam kung me raplacement kasi yung sa kin walang available na replacement kaya surplus na lang kinuha ko. :lol:
November 16th, 2002 06:56 PM #9
pilo,
Yung sa Pajero nabunot dati yung isang wire leading to the tranny. Humiga lang ako sa ilalim and I reconnected them. Ayos na. Smile na ulit ako.
- 37
November 18th, 2002 12:02 PM #10marami salamat sa mga reply. try ko silipin yung ilalim ng kotse. hirap kasi umatras pag gabi, di ko kita dahil sa tint
high idle RPM at engine start
