Results 1 to 7 of 7
- May 2005
- 82
October 1st, 2005 11:25 PM #1pano po ba? napundi kasi yung right eh... can't seem to figure out how to, though...
TIA!!!
October 2nd, 2005 12:14 AM #2
you'll have to go through the back side of the bumper (inside the wheel well). you can unscrew the socket and pull out the bulb there. itatabi mo lang yung fender lining covering the fog light area.
- May 2005
- 82
October 2nd, 2005 12:20 AM #3a ok... i thought i uunscrew yun sa harap ng fog light then pull it out...
anong bulb nga pala kinakabit dun?
thanks!
October 2nd, 2005 12:29 AM #4
ako i pull out the fog lamp assembly.tanggal muna yung frame.yung screw nun nasa taas or baba yata.yung nasa gilid wag mo galawin kasi pang adjust ng aim yun.
then, hilahin mo dahan dahan yung fog lamp assem. yung pinaka lock niya nasa taas.dalawa yun.basta hilahin mo dahan dahan with force.
tapos makukuha mo na ang assembly.
not sure ano exact model nung bulb.basta yung may wire pa..kumuha lang ako sa shop namin eh.herherher..im using all weather bulbs for all.
- May 2005
- 82
October 2nd, 2005 12:54 AM #7ayus!
pwede rin pala from the front ang pagpalit.... parang ang hirap kasi dukutin kung sa wheelwell dadaan eh...
high idle RPM at engine start
