Page 2 of 35 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 1387
    Quote Originally Posted by sirkosero View Post
    Ano ba ang plug and play retrofit?
    Was looking at xenon concepts, plug and play retrofit daw tapos their stage2 is reversible daw to halogen.
    Pano yun eh diba mas malaki ang projectors that h4 bulbs?
    They use mini H1 projectors that fit into the stock housing of your halogen headlamps. The projectors are of a smaller diameter compared to the D2S projectors which are used for complete retrofits.
    Jun 2005
    Thanks! Will get a retrofit soon. Been wondering what the difference between 4300k vs 5500k.
    I know it has something to do with colors (whiter, etc). Since im just getting a "no non-sense" upgrade (just retrofit, no angel eyes, etc), what do you think is the best color temp? I will need a good light that will help me see more even if it is raining hard at night.
    Yung 5500k ba puti talaga? What i know if white reflects sa rain so i try to get a good balance
    Jun 2012
    5500K is whiter. That is daylight.
    4300K is warm white.
    4300K is OEM HID. This is what most car manufacturers use on their cars because it has the highest effective output on the road.
    Some go as high as 5000K. I have 4800K installed in my retrofitted Mazda, and it's already at the limit of blueish for my taste.
    I wouldn't go for a higher color temperature at the expense of effective lighting output, because that defeats the point of spending for HIDs.
    Jun 2005
    ^ which is better in terms of visibility during a heavy rainy night? Based on my limited understanding, im inclined to get thr 4300k temp kasi mas mataas daw visible light, whatever that means.
    Apr 2014
    They say the 4300k has the more lumens or more visible light. If you wanna be safe, then get 4300k. I have 6000k in my mux but no problem naman but napansin ko parang mas visible yung halogen yellow sa white cement na road. Mas pogi kasi pure white na light eh.
    Functionality: 4300k
    Aesthetics: 5500k/6000k
    Oct 2015
    I have tried a car with 4300K hid and there's a very slight difference with the 5500K under heavy rain/fog - that's why I chose the latter for the closer to daylight color temperature.
    If you're unsure, you can always buy a separate pair of d2s HID bulbs then just swap it out whenever the need arises.
    Jan 2009
    4300K falls within the range of color temperature that is also known as neutral white. It has better utilization of the color spectrum so objects are rendered more naturally in their native colors and offers a well balanced contrast. There is minimal to no color spikes (especially in the blue region) so it is visually more comfortable to the eyes even on prolonged usage. Neutral white renders green and brown objects quite well
    Going above 5000K introduces varying degrees of spike in blue light with little to no presence of warmer colors. Human eyes are bad at focusing blue light and needs the warmer tones as many objects around us are red, green, brown, and yellow and because of that, contrast is diminished and everything tends to appear bland and flat.
    Aug 2012
    Sent from my ASUS_Z010D using Tapatalk
    Aug 2012
    Re: Yellow vs White light. It more depends on your preference and eyes. Some people see more with Yellow light. Some people see more with White light. Go with whatever is comfortable to you.
    There are cars that come with White light as stock already for both headlights and fog lights.
    Jun 2005
    Got my headlights retrofitted. Got bi-xenon with koito Q5 and 4300k bulb. Looks okay, i guess. Will try it this weekend
    Any pics? Curious to see Xenon Concept's workmanship.
    Jun 2005
    Got a few. Dont know how to post though
    Jun 2005
    Low beam
    Jun 2005
    Some samples
    Linis ng gawa, looks close to the projectors of the 1.5 Vios. 10k lang yan right? Sulit!
    Jun 2005
    Yup. 10k sya. I think okay naman for the price. Nakatago yung wirings.
    I suppose those are China projectors and HID? Had a bad experience with China projectors before sa fieldmaster. If im doing another retrofit, hanap muna ako ng surplus headlight housing to preserve the OEM housing.
    Feb 2003
    Yes it was mentioned in their FB post that they their projectors/ballast/bulbs are sourced directly from company in China, hence lowered price...but what brands ba ang really good and not made in China?....How about the materials from other well known retrofitters, what type of materials they used ba and where is it sourced?
    I've read in Ertiga FB add 1K for the angel eyes, and they do home service, done in 2.5 hrs.
Planning on getting an HID retrofit
