Results 1 to 10 of 1387
- Oct 2009
- 152
August 24th, 2017 05:36 PM #1nagparetrofit din ako sa wakas. pinagisipan ko din yung LED projectors, pero sa HID din ako bumagsak. Advantage lang ng LED projector is instant on pero as of now, for the same price mas malakas ang HID retrofits. For me ang main issue is longevity. Sa HID bubuksan lang ulit yung headlight if may leak or nasira ang solenoid. If mapundi ang bulb or masira ang ballast palit lang siya since nakalabas. Sa LED if may masira required na buksan ulit ang headlight kasi lahat nakapasok sa projector. Okay na din sana output niya even if mas mahina siya ng konti sa top of the line na HID retrofits, pero parang masyadong malaking chance for me na may mangyari so ayun, so ultimately nag decide ako na mag HID instead of LED.
- Dec 2014
- 165
August 24th, 2017 06:19 PM #2*zechs if the output is no longer as bright as newly installed, then a change in ballast would definitely improve your system. An upgrade from nhk to CBI is night and day difference. Go for it.
*mouse who offers led projector retrofit? Leds should give you longer service(more than the lifetime of the vehicle) that is why you should not be worrying on opening your headlamp assembly again provided its a reputable led brand. This is the same case for audis, mercs, murano, corolla, civic even the prius. HIDs tend to be very hot, and expensive to maintain. And yes the warm up time is annoying. You cant flash multiple times during daytime. Though they are king on widest beam pattern, led uses less power and gives better output than halogen.
August 24th, 2017 11:27 PM #3
Bago kasi sir. Yung unit ko nga ngayun naka stock HID projector na but philips 25w lang so gusto ko ng 35w ang problema is d5s ang size ng bulb ko which is integrated ang ballast. meron ng ganyan size and specs ang NHK pero di ako convince sa performance nya. last week nag labas ang morimoto ng d5s 35w. You wont believe the price. 350usd for a pair of bulbs alone. So I opted to buy na lang a morimoto md2s 4.0, morimoto xb5 ballast and philips xv c1 d2s bulbs. actually hindi magkaloyo ang price ng mga parts na nabanggit ko if compare mo sa if bili ako nag morimoto d5s 35w bulbs at 350usd" STIR lens + spacers at 45usd. bagong product lang kasi kaya mahal. baba din presyo nyan. having said that. wala pa talagang LED maka tapat sa performance ng HID in all aspects.
haba nang dicussion about HID vs LED kahapon sa HID headlight junkies fb group. May nag claim kasi a isang may ari ng company that LED is better than HID kaya binigyan cya ng challenge ng mga batikan na mga retrofitter sa US kasama na si andrew na taga TRS na unless may ma ipakit siyang output pics compare ng HID vs LED then everything is just marketing. Ans wala talag siyang ma ipakita pero sa mga HID guys dami proof. hehehe pwede ko screen shot mga comments nila if anybody wants a proof dinLast edited by D3nb3r; August 24th, 2017 at 11:40 PM. Reason: type errors/corrections
- Oct 2009
- 152
August 25th, 2017 10:22 PM #4*hypnos- Both HIDretrofit and Redline offer LED projectors now. On the LEDs, yes it is true that its lifetime should last the life of the car but I am worried about all the other parts which are attached to the LED to make it run. Almost everything is sealed in the assembly. I am also into collecting nice flashlights and usually for LED flashlights, circuits get broken rather than the LED itself. For cars these will be even more beat up. LEDs are also affected by heat, even if it theoretically produces less than HIDs (look at the big cooling fins behind current LED projectors). I would be okay with stock LED headlights (example: current 2.0V corolla or civic) since the manufacturer spent the time and money to test these to failure. However, for a retrofit involving aftermarket projectors being installed in a new, untested environment (my headlights), too many things can go wrong. For me, long term ease of maintenance outweighs my need for the instant on.
QUOTE=hypnos;2865610]*zechs if the output is no longer as bright as newly installed, then a change in ballast would definitely improve your system. An upgrade from nhk to CBI is night and day difference. Go for it.
*mouse who offers led projector retrofit? Leds should give you longer service(more than the lifetime of the vehicle) that is why you should not be worrying on opening your headlamp assembly again provided its a reputable led brand. This is the same case for audis, mercs, murano, corolla, civic even the prius. HIDs tend to be very hot, and expensive to maintain. And yes the warm up time is annoying. You cant flash multiple times during daytime. Though they are king on widest beam pattern, led uses less power and gives better output than halogen.[/QUOTE]
August 25th, 2017 11:56 PM #5
[/QUOTE]
The MLEDs and Bi-LEDs for morimoto have cooling fans. Now that is another thing to worry about since kalalabas pa lang ng product nila so mga mag lalabasan ang mga feedbacks nyan after a year or two. So for peace of mind and HID is still a good option. Will the LED be able to match the HID in light throw, width, longevity, etc.? only time will tell. Pero as what the experts in Headlight junkies group said "HID is still the king"
August 26th, 2017 03:22 AM #6
This is between HID retrofit and LED retrofit right?
Kasi kung OEM LED, mas malakas yung OEM LED ng Civic ko vs HID retrofit ko in my Mazda 3. Same with Altis 2.0V and Fortuner 2.4V vs Mazda 3 HID.
Stage 2.5 retrofit done by Redline with Q5 projectors and NHK bulbs.
August 26th, 2017 04:56 AM #7
When we say malakas, at what distance? Kaya nga yung iba nag claim na malakas daw ang LED or HID. But all those numbers and stories is nothing without proof using lux meter at least 25ft away with photo or video comparing each bulb or projector with the same camera exposure. Di kasali dyan ang pics na kuha ng phone lalo naka auto settings. Yung iba sa HIDplanet forum gumagamit ng low light exposure para ma compare ang hotspots ng bulb o projector na kinukomapara.
My previous rig was also retrofitted by redline. Pero when it comes to intensity IMO no oem LED can match a 3" FXR 2.0 + philips 85122 35w d2s bulb kahit that time NHK lang ballast ko. But then again its all hearsay kung wala ako proof. So sa plan ko sa DIY retrofit ngayun, I will use Morimoto md2s 4.0, Morimoto xb35 ballast and Philips XV C1, all of this items purchased from TRS. So If ever I would compare this parts meron akong back-up na datas. Both avalible sa lightwerkz and TRS site.
I'm not familiar with civics but yes I agree na ang led bulbs on fort and monty at the moment is way below on performance kahit di na gumamit ng measuring tools if compare mo sa properly retrofitted HID. Kaya dami nag papalit na mga naka stock led HL. But then again some folks are happy with it. But not me
edit: The phrase "HID is still the king" is from a thread kung saan yung LED guy is claiming that led bulbs are better than HID kahit na ginamit nya ang hid bulb sa halogen reflector housing. At may mga test din siyang ginawa mali nga lang according to the hid guys.Last edited by D3nb3r; August 26th, 2017 at 05:18 AM.
August 26th, 2017 10:29 AM #8
Retrofit vs OEM LED
Kahit sino tumingin, mas malakas LED ng Civic sa HID retrofit ng Mazda 3.
Those are taken using my SLR at the same exposure settings.
Dati pinaglalaban ko rin na mas malakas talaga retrofit vs OEM. But everytime I pull up my Mazda 3 beside a Fortuner or Altis 2.0V with stock LEDs, mas malakas talaga buga ng ilaw nila. Have never seen anyone with a 2.4V Fort still have their lights retrofitted - laging 2.4G kasi hindi naman LED yun.
Sent from my SM-N9208 using TapatalkLast edited by jut703; August 26th, 2017 at 10:42 AM.
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
