Need more light and visibility. Contemplating on either buying an Osram Nightbreaker or go HID. Car is Civic Ek SiR , Requesting for advice mga expertsthanks!
Almost the same ang ONB+ sa oem color. May thread na dito yan sir at dami na din query on the difference sa stock bulb.
Kung magHID ka sir, be responsible. HID alone will not give you more light and visibility - it should be used on a proper type of headlight(case).
Im no expert in HID pero nakikita ko maporma siya pero mga gunggong tawag ko sa mga irresponsableng naka HID, kasi nakakasilaw sa ibang motorista yan sir both yung nasa harap mo at kasalubong mo.
Sent from my GT-I9300 using Tapatalk
thanks sir! i also noticed the rather "irresponsible" use of HID, or would it caused by improper installation or just basically, not designed for the particular car? Anyways, im also considering the responsibility side here and not causing untoward inconvenience to others. I always had the impression that HID would give me more light and visibility.
Irresponsible because in the first place why put a bulb not designed for the headlight assembly you have, and the most responsible thing to do is look for an aftermarket headlight assembly (conversion works too, saw a thread by garyq) that will provide necessary stuff to make your hid work seamlessly (not just turning on/off and giving light).
pag HID pair it with a projector and dapat hindi fluted yung headlight lens mo.......... or pa retrofit ka kay sir garyq.
Any feed on the osram? I wanna change my grandias bulb. Cant see well at nite
bought ONB+ few months ago and mas okei kesa stock bulbs,
mas gusto ko din kulay ng buga nya, mas whiter ng kaunti kesa stock bulb,
but not as white as HIDs.
i have 3M medium black tints sa harap, and i see things clearly padin naman at night.
thou 20/20 vision padin ako.
If this will just be a bolt-on affair, the Nightbreakers. That should be a level up from stock.
If you want to go with HIDs, get projectors. The Morimoto mini H1 install is relatively bang for the buck, powerful and undoable.
The EK headlight is quite big, so it should be glaring all over the place.
Agree with IMm29. Also IMO, a properly retrofitted hid+projector will out-perform any nightbreakers kahit na yung mga aftermarket lang na morimoto MH1 or MD2S. Wala pang glare sa on-coming traffic. But if you have extra cash you can go full OEM for maximum output.
i would go for the ONBs.
More visibility compared to HIDs, imho.
I've tried both, and I went back to the ONBs.
Hid's are fine on regular headlight assembly, as long as you get the more expensive telescopic hi/lo type. Me umbrella sa dulo yon so hindi kakalat ang liwanag.
Di gaya ng mga gunggong na nagtitipid at bibili ng hid na mura pang motor na single bulb lang. Minsan halogen at hid pinagsama, pero wala pa din umbrella to simulate the low beam .
Sir, baka po heavily tinted ang windshield ninyo kaya di kayo makakita nang maayos. Have it remove or replaced with a lighter shade. If kulang pa rin, get those NB's
Still not that good. May glare pa rin yan telescopic HIDs. Retrofit pa rin ang best and long term solution
