Results 1 to 10 of 111
October 20th, 2013 04:48 AM #1
Need more light and visibility. Contemplating on either buying an Osram Nightbreaker or go HID. Car is Civic Ek SiR , Requesting for advice mga experts thanks!
October 20th, 2013 04:53 AM #2
Almost the same ang ONB+ sa oem color. May thread na dito yan sir at dami na din query on the difference sa stock bulb.
Kung magHID ka sir, be responsible. HID alone will not give you more light and visibility - it should be used on a proper type of headlight(case).
Im no expert in HID pero nakikita ko maporma siya pero mga gunggong tawag ko sa mga irresponsableng naka HID, kasi nakakasilaw sa ibang motorista yan sir both yung nasa harap mo at kasalubong mo.
Sent from my GT-I9300 using Tapatalk
October 20th, 2013 04:57 AM #3
thanks sir! i also noticed the rather "irresponsible" use of HID, or would it caused by improper installation or just basically, not designed for the particular car? Anyways, im also considering the responsibility side here and not causing untoward inconvenience to others. I always had the impression that HID would give me more light and visibility.
October 20th, 2013 05:12 AM #4
Irresponsible because in the first place why put a bulb not designed for the headlight assembly you have, and the most responsible thing to do is look for an aftermarket headlight assembly (conversion works too, saw a thread by garyq) that will provide necessary stuff to make your hid work seamlessly (not just turning on/off and giving light).
- Jun 2010
- 321
October 20th, 2013 10:56 AM #5pag HID pair it with a projector and dapat hindi fluted yung headlight lens mo.......... or pa retrofit ka kay sir garyq.
- Dec 2002
- 2,335
October 20th, 2013 11:07 AM #6
- Mar 2003
- 248
October 20th, 2013 07:14 PM #7Any feed on the osram? I wanna change my grandias bulb. Cant see well at nite
- Jun 2006
- 1,139
October 20th, 2013 07:54 PM #8Hid's are fine on regular headlight assembly, as long as you get the more expensive telescopic hi/lo type. Me umbrella sa dulo yon so hindi kakalat ang liwanag.
Di gaya ng mga gunggong na nagtitipid at bibili ng hid na mura pang motor na single bulb lang. Minsan halogen at hid pinagsama, pero wala pa din umbrella to simulate the low beam .
October 20th, 2013 08:29 PM #9
October 20th, 2013 09:30 PM #10
