Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    #21
    *impulzz ... thanks
    *always_yummy ... yup, no resistors needed, and you may connect the diode anywhere most convenient as long as it is consistent with the circuit (on the relay side or on the socket side, take your pick) ... the 1N4007 is recommended as it has higher reverse breakdown voltage rating than the usual 1N4001 used by hobbyists (1000V against 60V) yet they cost the same ... note that although our cars have 12V system, voltage transients can reach as high as 80-100 volts.
    *prodigi ... the diode orientation is correct as shown (cathode on the hi-trigger ... on a diode, cathode is the side with white mark), it allows the low-beam relay to enegize when the high-beam relay is also energized as the triggers are negatively switched, while only the low-beam relay is enegized when trigger switch is at low position ... when the diode is reversed, there is no danger of fire, but the switching action will be reversed, i.e., both high-beam and low-beam are lit during low-beam postion, and only high-beam is lit during high-beam position
    let me clarify what i undestood from impulzz's modification to his car ... his car originally uses the dual-filament headlamp bulb (was it H4?) ... and the original switching is that only one filament is lit at anytime headlights are triggered, only low-beam when low-triggered, or only high-beam when high-triggered ... but when he replaced the head lamps into two-bulb configuration, he wanted the low beam to remain lit during high-trigger ... and so he used relays to achieve the switching action. Although high-powered diodes without relays would achieve the same switching action, the diodes would introduce voltage drops and could significantly reduce power for the lamps, hence relays are best for the application.
    now i believe abort_retry's suggestion would also work ... in fact if one could access the original headlamp relays' circuit way inside the car (sometimes they are under the electrical assembly at the engine bay), a single 1N4007 diode would do the trick without additional relays
    #22
    i have no degree on electronics or something but i am reading through discussions of quadlamp conversion and it works with just a single piece of relay.... not sure though if my diagram will work.....
    #23
    yes abort_retry, your diagram will work as far as switching action is concerned but not advisable to install because it will now force the wire/s for high-beam to carry the low-beam current as well and might overload it, especially now that manufacturers tend to use wires that are "just enough" for the original design ... doubling the current on the wire might be pushing your luck if a fuse refuses to bust
    #24
    if you use the same wattage as before.... i think it should be ok... what really is important is that the positive polarity wiring is as thick as possible..... the negative wiring is i think less important that the positive side. or i might be wrong though kasi this time you are lighting up two bulbs.....
    #25
    or this..... wherein you have to re-wire the low beam bulb....
  6. #26
    will look on this too..time to review what i learned in my last 3 electronic subjects...
    masama talaga ang sobrang current...
    #27
    normal po ba na umiinit yung relay?
    #28
    could this Bosch Relay be used in dual fans?
    and what number is for battery source, (+)(-)switch, ground, and power out?
    85=?
    86=?
    87=?
    30=?
    Mar 2007
    #29
    guys, buhayin ko lang ito. nagpalit na ako ng harness matagal na. gusto ko gawing naka on ang low pag nag high ako.
    kailangan pa ba talaga ng additional relay? para 3 na relays na?
    #30
    peepz.
    how long would it take kaya para gawin to?
    any reputable shops in banawe that can do this?
    TIA
    #31
    suy suy - puputok ang bulb mo pag nag double engage.
    #32
    h4 bulb puputok pag minodify?
low/high beam wiring
